Well, I did a thing, It was a thing I knew better then to do, too. (Thermocouple connecting) |
VaccaRabite |
Oct 11 2023, 06:22 AM
En Garde! Group: Admin Posts: 13,584 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Continuing to live my life as an object lesson for others...
I recently had to pull my engine for some repairs. For me, part of pulling the engine includes removing the thermocouple from under the #3 spark plug and fishing it out of the engine tins. This runs to the CHT gauge in the cabin of the car. And we all know you are not supposed to cut the wire. Everybody knows that. So I figured I'd cut the wire, add a nice weatherproof automotive plug, and see what happens. All in the name of convenience and curiosity. I drove 300 miles last weekend. Including going fast up a really long couple of hills (like miles long hills) in 5th gear. So the results.... At cold start, the gauge reads the same as ambient temps. Under normal driving, the CHT gauge read slightly cooler then before I added the plug, but within 10 degrees of what I expected. However, when pushing the car, the error rate grew exponentially. Where I would expect the car to be running 340-350 head temps, the gage only showed about 300. And pushing 90 up hill in 5th for over a mile I would expect the gage to read 360+ the gage only ever got to 325. I did not push past what I know this engine required to get to 375 (which is my back off point). The result of this experiment is that if I did not know and expect bogus returns on the gage, I could easily roast an engine and start dropping valve seats, while a quality CHT gage was reporting I was WELL under the 400 degree danger zone. I have another cable I can swap in. Kind of a pain, but not a huge deal. I'll add it o the maintenance schedule. But, yeah. In this case the group think is accurate. The very slight resistance that the plug will add to the cable will be enough to throw off your CHT monitor. Do not cut the line between the thermocouple and your CHT gage. Zach |
nditiz1 |
Oct 11 2023, 07:00 AM
Senior Member Group: Members Posts: 1,202 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I'm guessing you didn't have a setup similar to the dakota digital? That thermocoupler has disconnects already built in. With that in mind I'm surprised your setup would be much different. I don't know much about the inner workings of thermo dynamics just that heat is transferred via these two wires to the gauge. I guess if the metals were dissimilar in your connection points that would cause a discrepancy. Good to know though about other types of CHTs.
VaccaRabite |
Oct 11 2023, 07:50 AM
I'm guessing you didn't have a setup similar to the dakota digital? That thermocoupler has disconnects already built in. With that in mind I'm surprised your setup would be much different. I don't know much about the inner workings of thermo dynamics just that heat is transferred via these two wires to the gauge. I guess if the metals were dissimilar in your connection points that would cause a discrepancy. Good to know though about other types of CHTs. It is a Dakota Digital actually. But the screws are under the tins. In the past I've always just fished everything out after pulling the #3 spark plug. The thermocouples only produce millivolts of voltage. You should be able to put a connector in series with the thermocouple as long as the connector doesn't add any resistance. It's only the tip of the thermocouple which produces the voltage. If you jiggle (official EE term) the connector while running does the gauge move around? I'll have to see. Easy enough test to do tonight after work. Driving over bumpy roads though did not seem to have an effect. Zach |
worn |
Oct 13 2023, 05:54 PM
can't remember Group: Members Posts: 3,325 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Getting the spark plug and ring out has always seemed such a major PITA. If you come up with a disconnect solution it will be a service to us all.
76-914 |
Oct 13 2023, 06:02 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,621 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Getting the spark plug and ring out has always seemed such a major PITA. If you come up with a disconnect solution it will be a service to us all. The OD of the ring can be gently filed down so that it slips into the round plug receptacle. I used a flat file from a needle file set because it was less aggressive. The material is very soft so do so with care. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 31st October 2024 - 07:29 PM |
