> Original Horn ID and operation questions
Literati914
post Oct 16 2023, 07:13 PM
While reassembling my ‘72 project it’s come time to figure out my horn situation. I found these two horns in a box and am not sure if one or both were original to the ‘72. My car does have the wiring for two horns but I can not remember if both of these were on it before disassembly. I kind of think the smaller one was on my ‘74 parts car.
Either way, I need to know: are these two normally used in conjunction with one another as low/high (quiet/loud (IMG:style_emoticons/default/biggrin.gif) ) - if that can even be determined without part #s? If they are both of the same volume I guess I’d just be using one - or do two quiet ones make a loud (IMG:style_emoticons/default/confused24.gif) Are there any knowledgeable horn experts that can help? Thanks
johnhora
post Oct 17 2023, 03:47 PM
The Hz noting is on the backside....sometime on the early horn it's hard to see because of all the crud/dirt covering it....
The early horns can usually be repaired....really it's just a clean up of the internals....it's an electro magnet pulling on a metal disc....
Open one up with the screws (good idea to soak) and check it out....you can't hurt it
- Lo-Fi Version Time is now: 22nd November 2024 - 02:39 PM
