Crankshaft Hub Bolt Loose? Torque spec?, Sigh... |
GregAmy |
Oct 22 2023, 11:20 AM
Advanced Member Group: Members Posts: 2,397 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Is it a known issue for the fan hub bolt to loosen?
Backstory: car started running like hell last Spring on my Microsquirt conversion. Wouldn't rev, #3 CHT going vertical, very hot exhaust. WTF, over? I checked some basic stuff, nothing found. Drove it again a week later and it seemed to be getting worse. Checked the ECU logs and all seemed normal, TPS, MPS, all working as expected. I even went back to a tune that worked great in November (only difference was cold startup stuff, which I can test/adjust in the Spring when it's colder), but still even worse. Checked timing with an adjustable light at full advance, spot on for what the ignition map was calling for. I parked the car. Life was busy this year and I just didn't have time to deal with it. But I trotted it out again in September, and it was just as bad. Since I had problems with the IGN4VW coil a year or so ago (mounted in a hot place and was cutting out), I replaced the coil with one from NAPA. Suddenly the car would not start at all. And when I looked at the ECU logs during cranking, I was seeing 0 RPMs. Bad crank position sensor? Today I put the car on the lift and visually inspected the crank position sensor (as well as I could, anyway; the toothed gear replaces the A/C spacer) and the spacing of the CPS tip to the teeth was clearly too large; whereas it should be about 50-thou, it was actually around 1/8"-3/16". I pried on the sensor bracket with a screwdriver, and it was solidly mounted, no looseness. I know I spent a LOT of time getting that sensor set just right during the install (you can't get it it with the engine installed). So I knew something was up. The sensor was solidly mounted, the toothed wheel was not loose, so there was only one thing to check... ..and yup, the hub bolt was loose, allowing the hub to walk outward. Sigh... I tightened it down - best spec I can find in the interwebs is 23ft-lbs - and of course the car fired right up and drives fine. I hope this didn't cause any other damage... Is this common? I've never seen it before. The engine was built in California and I truly don't recall who installed the hub, them or me. It's torqued down right now and I'm going to check it on a regular basis (I thought about pulling the bolt and putting Blue Loc-Tite on it, but if I lost that bolt in there then I'd be toast and would have to pull the engine to get it back. Arthritis in the thumbs and tennis elbow so NFW I'm tempting that Fate...) Oh, and then I broke the door cam actuator when I was putting it back in the garage..it just never ends, does it...? - GA |
Superhawk996 |
Oct 31 2023, 10:03 AM
914 Guru Group: Members Posts: 6,520 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Start coarse and work down - use Prussian blue to monitor progress until you have uniform contact around - across the entire taper . With lapping compound it’s not like you’ll ever take too much material off.
Pits below the surface are of zero concern but you don’t want any high spots. |
930cabman |
Oct 31 2023, 12:58 PM
Advanced Member Group: Members Posts: 3,695 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Start coarse and work down - use Prussian blue to monitor progress until you have uniform contact around - across the entire taper . With lapping compound it’s not like you’ll ever take too much material off. Pits below the surface are of zero concern but you don’t want any high spots. (IMG:style_emoticons/default/agree.gif) Knock down the high spots, the low spots will be 0 contact, but will not hurt you The high spots create point loads and will in a short time start to rock. You are looking for as close to 100% contact as you can get. The Prussian Blue will tell that story |
Lo-Fi Version | Time is now: 22nd November 2024 - 08:32 PM |
