Txbentleyboy |
Member ![]() ![]() Group: Members Posts: 73 Joined: 15-October 16 From: Davidson County, NC, USA Member No.: 20,498 Region Association: MidAtlantic Region ![]() ![]() |
Does the engine need to be removed to change the seals?
Any and all thoughts are appreciated! |
Jack Standz |
Member ![]() ![]() Group: Members Posts: 295 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() |
Come on people, it's only three 10mm (2 easy to get to) nuts and 1 fastener (easy to get to) located at the end of the oil cooler.
For only one fiddly nut, it's such a waste of time and effort to pull the engine IMHO. The reality is that it's so much more difficult just to remove the CV bolts & CVSs. And that's only a small part of removing the motor. Pull out an assortment of small extensions and a universal joint and get that little nut off. Then slide the cooler to the side. Then put some super glue (or grease) on the side of a long skinny screwdriver to properly locate the two seals. Do not over-tighten the fasteners. That's probably why it leaked. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:46 AM |
