first start of new motor, do I prime the oil pump?, should I have to prime it manually... whats wrong? |
brant |
Dec 26 2011, 04:46 PM
914 Wizard Group: Members Posts: 11,832 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
any builders out there care to give me tips?
I rebuilt a 2.0 4 cylinder and tried to do a first start up on it for Christmas day. Its in the garage... but very cold... probably had been around 10F the night before. The garage was warmed up with a kerosene heater, but I know the block was still pretty cold. Oil is brad Penn break in. Full rebuild... melling oil pump So I know the oil is cold, but I've got it a touch over full and know the oil filter will hold a tiny bit more by the time oil fills it and all of the passages. Its not cold like molasses... its still flowing and the ambient in the garage is probably 55-60 at this point. I pullled the coil wire and tried to turn the starter over to build pressure. After about 6 long cranks (approximately 8 seconds each?) I still don't have pressure on the gauge or the idiot light So I pull the sender wire and verify the gauge is OK. Next I pull the sender off of the end of its flexible tubing and point the tube into a bucket while the car is cranked one more time.... No oil in the flexible tube. Next I pull the oil filter and its got about 4/5ths (that I pre filled it with) but not wet and not full... no oil to the filter yet. Next I put a piece of hose onto the threaded collar that the oil filter normally screws onto. I blow with my mouth and there is a tiny bit of resistance but definitely not plugged. I can hear air blowing into the sump. finally I drain the oil and pull the tuna can... the pick up looks fine really from what I can tell through the sump hole. So the motor has been cranked about 9 or 10 times total I estimate that is about 90 seconds or a little less. the last 2 or 3 times I cranked it It started to turn a little faster or "more freely" which I assume is the bearings and things fitting into each other. I'm freaked about cranking it dry any longer. its got a new raby cam and everything... I don't want to damage the lifters, etc. I had used white lithium greas in the pump gears at assembly. Its a very viscous grease and shouldn't be "hard" from the temperature Questions: - Is there a way to prime the oil pump now? (maybe putting pressurized oil into the tubing on the oil filter collar, and having that run down hill into the pump gears?) - am I just being a freak... and need to keep cranking it over longer or more due to the cool weather? thanks in advance for any advice, especially "been there and know" kind of knowledge. brant |
technicalninja |
Nov 5 2023, 01:33 PM
Advanced Member Group: Members Posts: 2,260 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
I haven't had to try this on a T4 but on the very worst designed oiling system in the history of internal combustion engines this works GREAT!
Engine in question is the early "odd fire" 231 ci V6 that GM use in a bunch of stuff from the late 70s though the mid 80s. You could change the oil and loose the "pump prime" on these. Lots of engines were destroyed by poorly done oil changes... Remove either the oil filter OR the oil pressure sender and apply oil under pressure into the engine. We would remove the sender and install a hose we made up to a facet fuel pump (square box style). The inlet side of the fuel pump would get a hose that we'd put into a quart of oil. We would apply 4psi oil to the engine and then turn it backwards for 360 degrees which would prime the pump. This was the only way that worked every single time. Sort of a PIA but when nothing else would work this method did. After the "set up" was created the time it required to do this was under 5 minutes. I ALWAYS pre-pressurize a fresh motor in this manner after a build. Normally it's still on the engine stand out of the car. After install I kill fuel/spark and rotate it with the starter motor until the gauge sees pressure. If I can I fill oil filters before install during a normal oil change. Some designed do not allow this. |
Lo-Fi Version | Time is now: 15th January 2025 - 11:55 AM |
