Clutch action and tunnel repair...., Hoping I can fix my clutch pedal issue...who has done the tunnel repair?? |
second wind |
Nov 10 2023, 09:41 PM
Senior Member Group: Members Posts: 862 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hello out there....my clutch pedal action changed drastically recently and the usual is an old clutch cable giving out...well so far that is not the case and I even have removed my clutch pedal cluster thinking it was shot but now that it is out I compared it to my brand new pedal cluster on the shelf and they are identical in spring tension and other aspects...so basically my current pedal cluster is as good as new....so what to do next? I have heard of a problem with the braised in tubes in the tunnel for clutch/throttle cables that give out....can anyone please comment on this issue and how to fix? I am somewhat anxious about this repair and don't really know why....please someone tell what they know about this issue....thank you very much!!
gg |
JeffBowlsby |
Nov 11 2023, 10:04 AM
914 Wiring Harnesses Group: Members Posts: 8,787 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
R/R the shift lever assembly for access. Put a #2 phillips screwdriver in the end of the tube to stop the weld, drill holes then plug weld the tube to the side of the tunnel from the outside. No need to cut the tunnel.
Attached image(s) |
Lo-Fi Version | Time is now: 6th January 2025 - 02:18 AM |
