Clutch action and tunnel repair...., Hoping I can fix my clutch pedal issue...who has done the tunnel repair?? |
second wind |
Nov 10 2023, 09:41 PM
Senior Member Group: Members Posts: 862 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hello out there....my clutch pedal action changed drastically recently and the usual is an old clutch cable giving out...well so far that is not the case and I even have removed my clutch pedal cluster thinking it was shot but now that it is out I compared it to my brand new pedal cluster on the shelf and they are identical in spring tension and other aspects...so basically my current pedal cluster is as good as new....so what to do next? I have heard of a problem with the braised in tubes in the tunnel for clutch/throttle cables that give out....can anyone please comment on this issue and how to fix? I am somewhat anxious about this repair and don't really know why....please someone tell what they know about this issue....thank you very much!!
gg |
76-914 |
Nov 13 2023, 03:01 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,650 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Try rotating/turning the assm while gently pulling and pushing it until it will pass. That fitting on the front end needs to be aligned with the offset in the tube. I didn't read where you confirmed the center spot weld was intact. (IMG:style_emoticons/default/shades.gif)
Lo-Fi Version | Time is now: 6th January 2025 - 01:57 AM |
