> Clutch action and tunnel repair...., Hoping I can fix my clutch pedal issue...who has done the tunnel repair??
second wind
post Nov 10 2023, 09:41 PM
Hello out there....my clutch pedal action changed drastically recently and the usual is an old clutch cable giving out...well so far that is not the case and I even have removed my clutch pedal cluster thinking it was shot but now that it is out I compared it to my brand new pedal cluster on the shelf and they are identical in spring tension and other aspects...so basically my current pedal cluster is as good as new....so what to do next? I have heard of a problem with the braised in tubes in the tunnel for clutch/throttle cables that give out....can anyone please comment on this issue and how to fix? I am somewhat anxious about this repair and don't really know why....please someone tell what they know about this issue....thank you very much!!
gg
burton73
post Nov 13 2023, 04:08 PM
Senior member, and old dude
It's possible someone repaired it before and at the back of the car where it goes through the firewall, maybe there's a piece of slag from welding. My picture above shows a drill bit put in the front of that tube so it wouldn't make slag. Don't know how you fix it for sure but if it was mine, I'd figure out how where it was knocking. Probably cut the cable and run it back out the other way and clear the jam up point. Measure it with a wire from the back.
Bob B
second wind   Clutch action and tunnel repair....   Nov 10 2023, 09:41 PM
Montreal914   First look at the rear firewall to see if the end ...   Nov 10 2023, 10:31 PM
second wind   First look at the rear firewall to see if the end...   Nov 11 2023, 12:16 AM
second wind   Thank you very much everyone....NEED MORE....not r...   Nov 10 2023, 11:11 PM
barefoot   My clutch tube was completely detached at the fron...   Nov 11 2023, 07:41 AM
Superhawk996   :lol: This one is mine Tunnel was transplan...   Nov 11 2023, 09:50 AM
JeffBowlsby   R/R the shift lever assembly for access. Put a #2...   Nov 11 2023, 10:04 AM
burton73   R/R the shift lever assembly for access. Put a #...   Nov 12 2023, 10:39 AM
76-914   The front is the most common detach point. If you ...   Nov 11 2023, 10:09 AM
914Toy   The front is the most common detach point. If you...   Nov 11 2023, 07:29 PM
dr914@autoatlanta.com   read the repair procedure in the tech tips 700 app...   Nov 11 2023, 10:50 AM
930cabman   read the repair procedure in the tech tips 700 ap...   Nov 16 2023, 06:01 AM
DaveB   I don't have a suggestion for your next steps ...   Nov 18 2023, 02:17 PM
Spoke   There's some pictures of the clutch tube in my...   Nov 11 2023, 01:07 PM
second wind   Thank you all very much!!!! So my...   Nov 11 2023, 10:56 PM
technicalninja   As clutches wear the pedal pressure release force ...   Nov 12 2023, 01:22 AM
second wind   So making progress on my funky clutch pedal issue ...   Nov 13 2023, 12:20 PM
ndfrigi   So making progress on my funky clutch pedal issue...   Nov 13 2023, 03:30 PM
76-914   Try rotating/turning the assm while gently pulling...   Nov 13 2023, 03:01 PM
burton73   It's possible someone repaired it before and ...   Nov 13 2023, 04:08 PM
ndfrigi   It's possible someone repaired it before and ...   Nov 13 2023, 06:12 PM
Dave_Darling   We have also seen the inside of the tube corrode a...   Nov 13 2023, 11:31 PM
- Lo-Fi Version Time is now: 19th September 2026 - 12:37 AM
