Porsche 914-4 Weber Carb running rich, Weber Carb running rich on #4 only |
mturner7 |
Nov 12 2023, 07:29 PM
Newbie Group: Members Posts: 14 Joined: 8-May 22 From: Cupertino California Member No.: 26,532 Region Association: Northern California |
Hi Everyone,
My car is a 1974, 914-4 with a 2.0L (2056cc) engine. With Weber IDF 44's. My #4 cylinder is running really rich. All the others are fine. The Question is: What in the carburetor could most likely cause the plug to foul (Running very rich) like in my case? I've tried to adj the air/fuel mixture screw still no change. This is what I've done so far: 0) Did a compression check on all cylinders. All ok. (95-100psi) 1) Changed the plugs. 2) Changed the Cap and Rotor. 3) Changed the plug wires. 4) Verified all the jets are the same. 5) Set the Air flow on each carb, sync'd them 6) I cleaned all the jets with the carb in the car, ran and idled much better. 7) Verified Spark to that Cyl, got a hell of a shock out of it. 8) I'm running Elec-Ignition, Flamethrower Coil, 60,000volts. After doing all this, the #4 plug still fouls after only about 20 to 30 miles. It has to be the carburetor. I just pulled the carburetor. Thanks for the help. |
Spoke |
Nov 14 2023, 09:59 PM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Hijack (again):
On my 2056, I have some popping when the engine is pre-warm. No popping after warmed up. Carb settings: Weber IDF 40 28mm venturis, 115 mains Idle Jets: 50 airjets 200 F11 emulsion tube Recently adjusted valves (didn't change anything) No vacuum leaks. No info on cam or valves. (2L heads) Adjusted the idle vacuum for each side and idle bypass screws were all about 1 1/2 turns out. Engine ran pretty good. Then about a week ago, it started running very rough, like on 3 cylinders when at idle and light throttle. With heavy throttle, it pulled like crazy. Seemed like #2 was not firing. On cold start up and just idling with some revving, I checked the temps of the exhaust pipes and #2 pipe was cold. Pulled the plug wire while running (using an insulated hose pliers) and the engine slowed down a bit so the plug was firing. Sprayed carb cleaner on all the intake interfaces and no change in engine tune so likely no obvious vacuum leaks. I backed out the idle screw many turns and the engine smoothed out at idle. Took it for a ride and it ran ok; not great; just ok. Exhaust tubes were all similar heat so #2 was firing ok. I'm going to pull the carb and inspect. What should I be looking for? |
Lo-Fi Version | Time is now: 27th September 2024 - 10:20 AM |
