Crankshaft Hub Bolt Loose? Torque spec?, Sigh... |
GregAmy |
Oct 22 2023, 11:20 AM
Advanced Member Group: Members Posts: 2,314 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Is it a known issue for the fan hub bolt to loosen?
Backstory: car started running like hell last Spring on my Microsquirt conversion. Wouldn't rev, #3 CHT going vertical, very hot exhaust. WTF, over? I checked some basic stuff, nothing found. Drove it again a week later and it seemed to be getting worse. Checked the ECU logs and all seemed normal, TPS, MPS, all working as expected. I even went back to a tune that worked great in November (only difference was cold startup stuff, which I can test/adjust in the Spring when it's colder), but still even worse. Checked timing with an adjustable light at full advance, spot on for what the ignition map was calling for. I parked the car. Life was busy this year and I just didn't have time to deal with it. But I trotted it out again in September, and it was just as bad. Since I had problems with the IGN4VW coil a year or so ago (mounted in a hot place and was cutting out), I replaced the coil with one from NAPA. Suddenly the car would not start at all. And when I looked at the ECU logs during cranking, I was seeing 0 RPMs. Bad crank position sensor? Today I put the car on the lift and visually inspected the crank position sensor (as well as I could, anyway; the toothed gear replaces the A/C spacer) and the spacing of the CPS tip to the teeth was clearly too large; whereas it should be about 50-thou, it was actually around 1/8"-3/16". I pried on the sensor bracket with a screwdriver, and it was solidly mounted, no looseness. I know I spent a LOT of time getting that sensor set just right during the install (you can't get it it with the engine installed). So I knew something was up. The sensor was solidly mounted, the toothed wheel was not loose, so there was only one thing to check... ..and yup, the hub bolt was loose, allowing the hub to walk outward. Sigh... I tightened it down - best spec I can find in the interwebs is 23ft-lbs - and of course the car fired right up and drives fine. I hope this didn't cause any other damage... Is this common? I've never seen it before. The engine was built in California and I truly don't recall who installed the hub, them or me. It's torqued down right now and I'm going to check it on a regular basis (I thought about pulling the bolt and putting Blue Loc-Tite on it, but if I lost that bolt in there then I'd be toast and would have to pull the engine to get it back. Arthritis in the thumbs and tennis elbow so NFW I'm tempting that Fate...) Oh, and then I broke the door cam actuator when I was putting it back in the garage..it just never ends, does it...? - GA |
technicalninja |
Nov 17 2023, 09:50 AM
Senior Member Group: Members Posts: 1,423 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
@Superhawk996
I didn't intend to insinuate that you were wrong. I was referring to me! You are an absolutely top-notch source for knowledge. You will go through the trouble of looking stuff up like no-one else I know. I really appreciate your input. On the loosening up of the crank bolt BS. In 40 years of building stuff (very limited VW and Porsche) I've found as you improve horsepower you commonly need more vibration attenuation than less. In the Miata world the stock balancer is SO bad many tuners want an aftermarket balancer BEFORE a tuning session. The stock balancer is not good enough for double or triple the horsepower. Now, I'm tripling power on these, most of the T4 work on here doesn't triple the power so the need for increased balancing will be less. I've seen multiple threads in the short time I've been on here regarding crank noses being damaged. Many of these could be from improper mounting but there are enough of them that makes me think "maybe there's more to this than we realize". I like my street-based vehicles to have excessive damping. I'm also a believer in full weight flywheels to increase transmission life... Thanks again for a scientific look at the balancing requirements for an H layout engine. It has been informative! |
Superhawk996 |
Nov 17 2023, 01:05 PM
914 Guru Group: Members Posts: 5,992 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
In the Miata world the stock balancer is SO bad many tuners want an aftermarket balancer BEFORE a tuning session. The stock balancer is not good enough for double or triple the horsepower. Here’s the thing. The Miata harmonic damper is PERFECTLY adequate for a stock engine - which is what Mazda designed it for. It’s not fair to say the damper is inadequate for an engine that has been modified for 2x or 3x the horsepower. Many things in the engine are going to be inadequate at that point. I had a stock 91’ Miata that was regularly autocrossed and ran weekend track days. That Miata went to 228k before I finally had to let it go due to rust that was getting too dicey. No issues what so ever with the stock harmonic damper or engine durability. I gave it away with the engine still running strongly. The video below is from my car - used to collect a bet for a case of beer that the engine wouldn’t last to 100k without a rebuild the way I was driving it. I easily won the 100k bet at which point he wanted to go 200k - double or nothing. The beer was great (IMG:style_emoticons/default/beerchug.gif) https://www.youtube.com/watch?v=6-m2IT4Xojo?si=jJjnsojGL3tlJ9w9 |
Lo-Fi Version | Time is now: 25th June 2024 - 07:47 PM |
