> Order of operations: front suspension
rjames
post Nov 17 2023, 01:52 PM
I'm made of metal
Double post
Ishley
post Nov 17 2023, 09:37 PM
One issue that you want to be very careful with is bolt breakage. I broke a few and it really can set you back. Use a small 3/8 ratchet and go slow on disassembling the parts. Sometimes try to tighten them first. Whack the bolt hard with a hammer to help break it free. If you get out the big breaker bar you can snap a bolt in a flash. The pan under steering rack has 2 bolts in the rear that hold the aux suspension carrier. These are critical and are exposes directly to the elements. Use heat when things won’t move. If you have to repaint… it’s still faster then all the crazy stuff you’ll do to get a broken bolt out. Also… if you use a torch… the fuel tank has to be out. Don’t risk it.
For the ball joint you need a special socket and probably a powerful driver.
The early cars have a difficult bolt that clamps the strut to the ball joint. Lube and heat is the best way. I use a torch setup with mapp and oxygen. The O2 is expensive but you can get bolts red hot.
Of course good jack stands with a backup as you’ll be pushing and shoving against the car. I always setup a second set of stands as a backup.
Good luck!
rjames   Order of operations: front suspension   Nov 17 2023, 01:52 PM
rjames   My steering has started to feel 'floaty' a...   Nov 17 2023, 01:52 PM
Mikey914   You got all the usual suspects, so yes you will im...   Nov 17 2023, 02:00 PM
mepstein   No, you can hang the calipers away from the struts...   Nov 17 2023, 02:12 PM
Shivers   No, you can hang the calipers away from the strut...   Nov 17 2023, 03:43 PM
mepstein   No, you can hang the calipers away from the stru...   Nov 17 2023, 03:55 PM
914_teener   If you haven't done rotors and bearings and ra...   Nov 17 2023, 02:47 PM
rjames   If you haven't done rotors and bearings and r...   Nov 17 2023, 05:02 PM
burton73   I had to post this here as well. Shown is the fro...   Nov 17 2023, 04:29 PM
rjames   I had to post this here as well. Shown is the fr...   Nov 17 2023, 05:13 PM
SirAndy   That pic makes me want to drop everything. Seems l...   Nov 17 2023, 05:16 PM
rjames   That pic makes me want to drop everything. Seems ...   Nov 17 2023, 05:20 PM
SirAndy   After looking at the above picture again, it looks...   Nov 17 2023, 07:23 PM
yellowporky   When i did my 73 1.7 i could not bring myself to i...   Nov 17 2023, 09:21 PM
Ishley   One issue that you want to be very careful with is...   Nov 17 2023, 09:37 PM
rjames   Got the tank out. Bulkhead area could use a little...   Nov 27 2023, 10:30 AM
burton73   Got the tank out. Bulkhead area could use a littl...   Nov 27 2023, 11:01 AM
rjames   Reading that I can remove the rack without removin...   Nov 27 2023, 02:16 PM
SirAndy   Reading that I can remove the rack without removi...   Nov 27 2023, 05:45 PM
rjames   Finally moving on this. Figured I'd continue t...   Jan 21 2024, 05:02 PM
jhynesrockmtn   I did the whole front on my BB last year. New str...   Jan 21 2024, 05:21 PM
iankarr   Glad my bleeding knuckles helped the greater good ...   Jan 21 2024, 05:28 PM
r_towle   I remember when I was doing autox weekly, I replac...   Jan 22 2024, 05:07 PM
rjames   Happy to report that last night I was able to fina...   Jan 23 2024, 10:41 AM
pek771   Your rack needs maintenance, at best   Jan 24 2024, 11:26 AM
rjames   More progress, slow, but progress none the less: G...   Jan 26 2024, 07:47 PM
DennisV   Now I've got this to deal with. All the vids ...   Jan 27 2024, 05:35 AM
rjames   Got the gland nut off finally after applying heat ...   Jan 29 2024, 09:53 PM
r_towle   Making progress….woohoo! I have a 2006 997 ...   Jan 30 2024, 08:58 PM
rjames   Thanks, Rich. Yeah- I'm already residing mysel...   Feb 1 2024, 06:33 PM
rjames   It took a while, but I got 99% of the undercoating...   Feb 9 2024, 01:12 PM
iankarr   I don't remember which manual I got those numb...   Feb 9 2024, 11:20 PM
Superhawk996   21 and 14 are the correct angles to allow the LCA ...   Feb 10 2024, 07:26 AM
rjames   21 and 14 are the correct angles to allow the LCA...   Feb 10 2024, 05:13 PM
Superhawk996   I'm still trying to figure out how they could...   Feb 10 2024, 08:56 PM
rjames   I'm still trying to figure out how they coul...   Feb 10 2024, 11:02 PM
DRPHIL914   @rjames wow great job, thats a big job to tackle...   Feb 10 2024, 08:44 AM
rjames   @DRPHIL914 I went with Konis front and rear when...   Feb 10 2024, 05:11 PM
rjames   Spent several hours last night removing the tie ro...   Feb 18 2024, 12:05 PM
jhynesrockmtn   Spent several hours last night removing the tie r...   Feb 18 2024, 02:11 PM
rjames   @jhynesrockmtn Thanks! Others have said the s...   Feb 18 2024, 02:24 PM
jhynesrockmtn   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Feb 18 2024, 07:47 PM
rjames   Finally got some more work done. Crossmember and ...   Mar 15 2024, 03:46 PM
TargaToy   Finally got some more work done. Crossmember and...   Mar 16 2024, 07:47 PM
rjames   @TargaToy Thanks for sharing your experience. Th...   Mar 18 2024, 10:05 PM
jhynesrockmtn   Looking good! I'd replace the bearing, th...   Mar 19 2024, 07:19 PM
rjames   Parts ready to go back on the car when the rack re...   Mar 20 2024, 07:26 PM
rjames   While waiting for my rebuilt rack to come back fro...   Mar 25 2024, 02:22 PM
jhynesrockmtn   While waiting for my rebuilt rack to come back fr...   Mar 26 2024, 08:35 AM
rjames   In hindsight I wish I had left the original plasti...   Mar 31 2024, 01:50 PM
rjames   Just got a package today. A few weeks ago I sent t...   May 3 2024, 08:54 PM
rjames   Got the steering rack and the suspension crossmemb...   Jun 2 2024, 06:50 PM
rjames   Ok to reuse these ball joint/strut wedge pins or ...   Jun 5 2024, 11:14 AM
Geezer914   I installed RSR bushings front and rear. 19 mm to...   Jun 5 2024, 12:06 PM
rjames   In absence of a response I went ahead and ordered ...   Jun 7 2024, 10:19 PM
rjames   Ready to install the new ball joints and Koni stru...   Jun 11 2024, 10:09 AM
rjames   Struts installed in the housings. Getting the glan...   Jun 26 2024, 04:51 PM
rjames   On to the ball joints. I made the mistake of tryin...   Jun 26 2024, 05:01 PM
Superhawk996   :cheer: you’re getting there!!!   Jun 26 2024, 11:11 PM
rjames   2 steps forward, 1 step back... Still awaiting Si...   Jul 2 2024, 09:43 AM
rjames   I'm replacing all of the fuel lines with Gates...   Jul 2 2024, 09:51 AM
rjames   Hopefully you never have to return something to Si...   Jul 10 2024, 10:26 AM
rjames   Holy crap. I just realized that I started the fron...   Jul 22 2024, 11:40 AM
DennisV   Holy crap. I just realized that I started the fro...   Jul 23 2024, 08:15 AM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 08:19 PM
