Fun with Electricity, PO Stuff #5 in the series, or is it #6? |
NARP74 |
Sep 25 2023, 12:25 PM
Senior Member Group: Members Posts: 1,308 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Going to RRC2023 last week, I lost all my gauges just after leaving home. Pulled over to check things out and found a blown fuse. Blew a couple more before I figured out it was the left turn signal. Didn't use them for the rest of the weekend. I asked around and someone suggested I check the flasher or turn signal relay. I dropped the fuse panel and found this. Did someone swap my relays around?
More in this thread to follow. I found lots of crap... |
campbellcj |
Nov 19 2023, 07:32 AM
I can't Re Member Group: Members Posts: 4,598 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
^^^ I just went thru the same thing - pulled my hair out going back over all the wiring to no avail, then talked to my mechanic who suggested it might be the actual switch and so I found one on the samba board and voila that was it. Not a cure-all but these switches are complicated mechanically and do wear or break after ~50 years.
Lo-Fi Version | Time is now: 15th January 2025 - 06:07 AM |
