> Fun with Electricity, PO Stuff #5 in the series, or is it #6?
NARP74
post Sep 25 2023, 12:25 PM
Going to RRC2023 last week, I lost all my gauges just after leaving home. Pulled over to check things out and found a blown fuse. Blew a couple more before I figured out it was the left turn signal. Didn't use them for the rest of the weekend. I asked around and someone suggested I check the flasher or turn signal relay. I dropped the fuse panel and found this. Did someone swap my relays around?
More in this thread to follow. I found lots of crap...
Tbrown4x4
post Nov 19 2023, 09:06 AM
I have had good luck finding intermittent shorts by replacing the fuse that is blowing with a sealed beam headlight wired to the fuse panel. When the short would blow the fuse, instead it lights the headlight. When the normal circuit load is flowing, the filament passes the current without lighting.
I hope I explained that well enough.
NARP74
post Nov 19 2023, 09:23 AM
QUOTE(Tbrown4x4 @ Nov 19 2023, 08:06 AM) *
Interesting idea. I have been looking for something creative like this so I can "see" what is going on.
I guess I would have to look for escaping smoke too since the headlight would take more than the amps rating of the fuse?
NARP74   Fun with Electricity   Sep 25 2023, 12:25 PM
87m491   They are not in the same location/order as mine, b...   Sep 25 2023, 12:47 PM
NARP74   I guess the bases could be swapped. I'll have...   Sep 25 2023, 12:50 PM
Dave_Darling   The electrons don't care where the relays are....   Sep 26 2023, 01:26 AM
914Sixer   I see lots of NON STOCK wires in the background. ...   Sep 26 2023, 05:36 AM
NARP74   I have not even started looking at the non stock w...   Sep 26 2023, 10:06 AM
NARP74   It gets worse. Why was this cut and bypassed?   Sep 26 2023, 10:08 AM
Spoke   It gets worse. Why was this cut and bypassed? ...   Nov 21 2023, 11:23 AM
NARP74   What is this add on wire for?   Sep 26 2023, 10:08 AM
87m491   That is a jumper wire to make the later 5 pin dire...   Sep 26 2023, 07:59 PM
jim_hoyland   I had a similiar issue and is was: “If the left ...   Sep 26 2023, 10:50 AM
NARP74   Swapped relays with others I had, no change. Foun...   Oct 14 2023, 02:35 PM
NARP74   Been working on this for a while now. I managed t...   Nov 17 2023, 01:03 PM
NARP74   Any ideas here???   Nov 18 2023, 10:28 AM
Ishley   I can’t say definitively… but I had gremlins i...   Nov 18 2023, 07:09 PM
campbellcj   ^^^ I just went thru the same thing - pulled my ha...   Nov 19 2023, 07:32 AM
NARP74   Buying NOS or used old ones on Samba? Any good ne...   Nov 19 2023, 08:59 AM
campbellcj   Buying NOS or used old ones on Samba? Any good n...   Nov 20 2023, 05:24 PM
Tbrown4x4   I have had good luck finding intermittent shorts b...   Nov 19 2023, 09:06 AM
NARP74   I have had good luck finding intermittent shorts ...   Nov 19 2023, 09:23 AM
76-914   After you cleaned and replaced the bulbs you now h...   Nov 19 2023, 09:23 AM
NARP74   After you cleaned and replaced the bulbs you now ...   Nov 19 2023, 09:30 AM
Spoke   I figured out it was the left turn signal. Keep ...   Nov 19 2023, 09:57 AM
Tbrown4x4   I have had good luck finding intermittent shorts...   Nov 19 2023, 06:31 PM
NARP74   So the latest is that the fuse has stopped blowing...   Nov 20 2023, 09:27 AM
Spoke   And for the dial gauge indicators, are the arrows...   Nov 20 2023, 09:57 PM
87m491   I can't be the only one trying to use LED bu...   Nov 22 2023, 03:08 PM
NARP74   I can't be the only one trying to use LED b...   Nov 22 2023, 03:40 PM
VaccaRabite   Its the switch. You need a switch that is designe...   Nov 20 2023, 10:57 AM
NARP74   I have talked to a few people and verified on anot...   Nov 20 2023, 01:58 PM
NARP74   Car is a 74, but... it has a Gates dash conversion...   Nov 21 2023, 09:16 AM
Spoke   Car is a 74, but... it has a Gates dash conversio...   Nov 21 2023, 11:07 AM
majkos1   Don't you have Five gauges ? That's a Gett...   Nov 21 2023, 04:46 PM
NARP74   Don't you have Five gauges ? That's a Get...   Nov 22 2023, 09:14 AM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 15th January 2025 - 05:59 AM
