> Low butt, Rear is a little low
Boothy
post Nov 20 2023, 08:42 AM
Morning!
I FINALLY got my '74 back on its feet and running. Her butt is riding low. I read a few of the posts here but still fuzzy.
I have Koni Reds and I read that they have an adjuster. But it that for firmness of ride height?
It's just a commuter so I don't need anything wild. Do I adjust the shocks, put in bigger springs, progressive springs? Bump up to 200lb springs? I see the adjusters you can buy.
Thanks!
bdstone914
post Nov 20 2023, 09:14 AM
bdstone914
A slightly nose down stance is best. Measure the distance from the rocker panels to the ground. You can raise the back or lower the front.
I have sone Koni soribg spacers if you want to raise the back. Requires removing the shock assembly and sorings and putting the spacer under the lower perch.
@Boothy
Boothy
post Nov 20 2023, 09:44 AM
QUOTE(bdstone914 @ Nov 20 2023, 10:14 AM) *
@Boothy
PM sent on the spacers. Thanks!
- Lo-Fi Version Time is now: 15th January 2025 - 03:44 AM
