Fun with Electricity, PO Stuff #5 in the series, or is it #6? |
NARP74 |
Sep 25 2023, 12:25 PM
Senior Member Group: Members Posts: 1,308 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Going to RRC2023 last week, I lost all my gauges just after leaving home. Pulled over to check things out and found a blown fuse. Blew a couple more before I figured out it was the left turn signal. Didn't use them for the rest of the weekend. I asked around and someone suggested I check the flasher or turn signal relay. I dropped the fuse panel and found this. Did someone swap my relays around?
More in this thread to follow. I found lots of crap... |
VaccaRabite |
Nov 20 2023, 10:57 AM
En Garde! Group: Admin Posts: 13,636 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Its the switch. You need a switch that is designed for LED bulbs. The LED bulbs draw too little power for the old switch to realize they are turned on, causing unexplained issues. There is a modern switch you can put it that might cure your issues.
I have full LEDs. On my car the switch won't blink the indicator on the dashboard. I have the new switch to install (and have had it for years now) but I have not gotten around to installing it. Remember that LEDs are also Diodes. Incandescent bulbs are not, and don't care how they are wired. If there are crossed wires in the front somewhere the LEDs won't work. Zach |
Lo-Fi Version | Time is now: 15th January 2025 - 05:51 AM |
