H2ohs |
Newbie ![]() Group: Members Posts: 15 Joined: 23-October 22 From: NH Member No.: 26,941 Region Association: North East States ![]() |
Hello, just ordered a replacement muffler for a 72 1.7 and it does not line up. New is about 1.75 wider compared to old (what is there) and does not line up with the flanges. I’m wondering if what is in my car is stock or not? It looks like my hanger has been cut too? Thoughts?
Attached thumbnail(s) ![]() |
H2ohs |
Awesome, thanks! Any advantage to the 2.0 over the 1.7/8?
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,439 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
Awesome, thanks! Any advantage to the 2.0 over the 1.7/8? original stock 2.0 muffler is very much like the design of the 911 muffler of the same period. internals probably more free flowing than VW muffler. stock 1.7 /1.8 muffler is a standard VW type 4 muffler more or less. there is a bit more to it when it comes to those but basically the later style muffler without the extra little tailpipe attenuator section is slightly more free flowing than the earlier ones. the earlier ones are straight off the VW 411 sedan and were designed for acoustic suppression (german TUV and USA noise level limits). the later single piece muffler is pretty much the VW bus muffler. its a tiny bit louder and a tiny bit less restricted believe it or not. but we are talking engines with 70-80 hp so don't think a 2.0 muffler on a 1.7 makes much of a difference to a 1.7 (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) also the 2.0 repro stock muffler available are generally more expensive than the 1.7/1.8 unit. at least when you compare the prices for the dansk unit. and the bus muffler is even cheaper than either of them and there is a trick to using one. they bolt straight on but will exit the wrong side. but there is a trick if you have a grinder and you can weld. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:37 AM |
