slapshot |
Member ![]() ![]() Group: Members Posts: 143 Joined: 11-June 23 From: Utah Member No.: 27,409 Region Association: Rocky Mountains ![]() ![]() |
Anyone know if any of these parts should NOT be cleaned in an ultrasonic cleaner? I picked up these parts to convert back to FI. I don't want to ruin any of them but need them to be in good working order.
Attached image(s) ![]() ![]() ![]() |
914sgofast2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 709 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None ![]() |
I agree that nothing electrical should be put in the ultrasonic cleaner. All the hard parts can go in it. Also put the oil filler "chimney" assembly in the ultrasonic cleaner. You will be very surprised about the amount of crud that comes out of the oil filler baffles in the oil filler chimney assembly.
slapshot |
I agree that nothing electrical should be put in the ultrasonic cleaner. All the hard parts can go in it. Also put the oil filler "chimney" assembly in the ultrasonic cleaner. You will be very surprised about the amount of crud that comes out of the oil filler baffles in the oil filler chimney assembly. Thanks for the tip! My pics were very vague, they were just some I had available. Parts still in question would be fuel pressure regulator Aux air valve Injectors Thanks |
Lo-Fi Version | Time is now: 19th April 2025 - 03:23 AM |
