> OT: 914 Front Turnsignal Bucket for 356 Rear Turnsignals, Custom LED time
Spoke
post Oct 28 2023, 12:26 PM
Jerry
Apparently 356 guys use the front turnsignal bucket from the 914 for rear turnsignals and brakes. They actually look really nice.
A fellow asked if I could design some LEDs for the application. The LEDs will be red and will serve as the running lights, brake lights, and turnsignals.
The picture below is not his car. He originally wanted to do red running/brake LEDs under the red portion and amber LEDs under the amber portion.
After some discussion, we decided to do all red LEDs for running/brake/turnsignals. So the entire lens will be red or clear.
Since the boards are at a unique angle left to right, a one-sided board cannot be used on both sides. So this board will be reversible. The LEDs can be mounted on either side of the board as well as all the components. This was a very busy board with all the extra components on both sides.
To be able to blink the turnsignals when the brakes are on, I'm using the same blanking circuit that I use on the 914 euro front turnsignals.
TheRuttmeister
post Dec 3 2023, 05:32 PM
Have you tested amber LED's under the red lens?
There's a very good chance that the red lens will block the amber completely, if you are still thinking about that option.
Spoke
post Dec 3 2023, 05:43 PM
Jerry
QUOTE(TheRuttmeister @ Dec 3 2023, 06:32 PM) *
Yes I checked amber LEDs under red lens and you are correct. The red lens does not block the amber completely but enough to avoid doing it.
Red LEDs under amber lenses work very well. Actually red LEDs come through amber lenses better than red lenses. With colored LEDs like I use, the most light is realized with clear lenses.
I'm running red rear turnsignals with amber lenses. I wish I hadn't changed out my red turnsignal lenses for amber. With red LEDs for rear turnsignals, I'm able to light them up gently for much increased rear running light footprint at night.
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th November 2024 - 05:48 AM
