vjb206 |
Newbie ![]() Group: Members Posts: 32 Joined: 23-December 19 From: New Jersey Member No.: 23,760 Region Association: North East States ![]() |
Hey folks! I've got...
I started by measuring all of the the main journals on the crank and I got a range from 2.358” - 2.360” (I used a digital caliper and I'm pretty sure I did this correctly). Then I “dry-fit” Silverline STD/STD main bearings into the case (sans crank), torqued everything down, and got 0.003” in radial play (I used a cylinder bore dial gauge for the first time, and I think I did it correctly). The spec-sheet says radial play should be between 0.06” - 0.10” (0.03” - 0.09” for #2); and I have 0.003." I'm a MINIMUM of 0.057" off, is that normal? What's my next step?
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,810 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
To measure the crank, I would use a micrometer, not a caliper.
You will want to check the cylinder spigot on the case for flatness (they get hammered down). You want to check everything on that case and do the galley plugs. You will want to check your oil pump fit too, and the interference with the cam shaft, but you probably know that and aren't there yet. Be prepared to dry fit open and close that case many times. With your case torqued on your bearings, check to make sure the case halves are actually closed using a back light. On my 2056 assembly, when I did that step, I could see light between the two halves. The bearing halves were in contact, but not the case. I doubt you can do the line bore without the proper boring bar and the milling that will allow you this setup. Obviously many more verification steps to come, but the case, line bore, spigot flatness, spigot distance to center line, etc... Rod interference check is another important one. Rods to case depending which rod you are using. Also rod to cam. Van Svenson has nice videos on his build including issues he had. There used to be a website with his step by step process but the link seems to be broken. If someone has it, please share it. (IMG:style_emoticons/default/smile.gif) This was it: http://www.ephotomotion.com/914engine/ Share your progress! (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 26th April 2025 - 08:24 PM |
