Welding advice, Can a cheap flux welder do what I need? |
Deusexmachina77 |
Nov 25 2023, 11:24 AM
Member Group: Members Posts: 96 Joined: 30-March 22 From: Chicago Member No.: 26,426 Region Association: Upper MidWest |
I have to weld in a new front trunk pan replacing the hole left from an AC unit. I have taken two MIG classes. Beside being a newbie, I have other limitations to consider.
I don’t have access to a 220 line. I’m inexperienced. It would cost me $1000 to have it professionally done. And I don’t want to buy a bunch of equipment for one job. Can I use a flux welder? There a couple cheap units at Harbor Freight (under $150) on sale right now. What don’t I know that I should know? Thanks (IMG:style_emoticons/default/welder.gif) |
Deusexmachina77 |
Dec 11 2023, 08:26 AM
After much deliberation and searching, I found the best option for my situation—a friend with a welder AND a garage to work on it.
I have another question for this group since you were all so helpful. Should I butt weld or lap weld the new floor pan in? I'm thinking lap weld. I don't want to weld from the bottom. I don't have access to a lift, and I'm not going to be able to weld on my back. I'm too old for that. Attached thumbnail(s) |
Spoke |
Dec 11 2023, 12:19 PM
Jerry Group: Members Posts: 7,107 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
After much deliberation and searching, I found the best option for my situation—a friend with a welder AND a garage to work on it. I have another question for this group since you were all so helpful. Should I butt weld or lap weld the new floor pan in? I'm thinking lap weld. I don't want to weld from the bottom. I don't have access to a lift, and I'm not going to be able to weld on my back. I'm too old for that. I've butt welded a bunch of small panels on the floor of my 914 w/o going under the car. All done from the top. |
930cabman |
Dec 12 2023, 02:44 PM
Advanced Member Group: Members Posts: 3,806 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
After much deliberation and searching, I found the best option for my situation—a friend with a welder AND a garage to work on it. I have another question for this group since you were all so helpful. Should I butt weld or lap weld the new floor pan in? I'm thinking lap weld. I don't want to weld from the bottom. I don't have access to a lift, and I'm not going to be able to weld on my back. I'm too old for that. I've butt welded a bunch of small panels on the floor of my 914 w/o going under the car. All done from the top. Being a CSOB I suppose a bunch is cheaper/easier than an entire floor pan. I will probably follow suit. |
Lo-Fi Version | Time is now: 6th January 2025 - 05:54 PM |
