> Welding advice, Can a cheap flux welder do what I need?
Deusexmachina77
post Nov 25 2023, 11:24 AM
I have to weld in a new front trunk pan replacing the hole left from an AC unit. I have taken two MIG classes. Beside being a newbie, I have other limitations to consider.
I don’t have access to a 220 line.
I’m inexperienced.
It would cost me $1000 to have it professionally done. And I don’t want to buy a bunch of equipment for one job.
Can I use a flux welder? There a couple cheap units at Harbor Freight (under $150) on sale right now. What don’t I know that I should know?
Thanks (IMG:style_emoticons/default/welder.gif)
Deusexmachina77
post Dec 13 2023, 04:49 PM
@mb911 That TIG weld is a thing of beauty. I only have access to a MIG welder and am not skilled enough to lay down beads like that.
Re-reading my follow-up post, the litany of not wanting to weld from the bottom was about the lap weld. I thought I would have to do the top and the bottom.
I have a pretty good mess to clean up first, so I'll see how I do with all that work first. And then I'll decide how comfortable I am with the butt weld. I usually have to do things twice. Something tells me I'll be paying a professional–eventually.
Thank you everyone for your thoughts. It is a constructive discussion. I've learned a lot. (IMG:style_emoticons/default/smilie_pokal.gif)
mb911
post Dec 13 2023, 04:56 PM
QUOTE(Deusexmachina77 @ Dec 13 2023, 02:49 PM) *
Use magnets to hold the but joint tight until it’s tacked in.
Deusexmachina77   Welding advice   Nov 25 2023, 11:24 AM
Shivers   Just patching the hole, absolutely. I do all sorts...   Nov 25 2023, 11:31 AM
iankarr   Get a 120v Hobart Handler. U can set it up for mig...   Nov 25 2023, 11:32 AM
Superhawk996   May I suggest you’ve asked the wrong question. ...   Nov 25 2023, 12:03 PM
930cabman   May I suggest you’ve asked the wrong question. ...   Nov 25 2023, 12:35 PM
Superhawk996   Looked up what is on sale Definately don’t get...   Nov 25 2023, 12:38 PM
rjames   Echoing the advice to look for a quality unit that...   Nov 25 2023, 01:08 PM
Deusexmachina77   Guys, Thanks everyone for really good advice. I w...   Nov 25 2023, 03:12 PM
Superhawk996   felt I didn’t know enough to evaluate the cond...   Nov 25 2023, 05:47 PM
mb911   Ugh I need to do a sticky on this. Superhawk has y...   Nov 25 2023, 07:54 PM
bkrantz   Find a friend with a welder. Or (better) find a f...   Nov 25 2023, 08:13 PM
emerygt350   I have had the titanium for 4 years now. I have u...   Nov 26 2023, 07:15 AM
IronHillRestorations   True MIG (shielding gas) is the only way to go for...   Nov 26 2023, 08:12 AM
stownsen914   As a self taught hobbyist welder, I'd have to ...   Nov 26 2023, 08:21 AM
Mayne   I have a small Titanium flux core welder that has ...   Nov 26 2023, 08:43 AM
Spoke   I don’t have access to a 220 line. I was worri...   Nov 26 2023, 08:48 AM
MikeK   I have to weld in a new front trunk pan replacing...   Nov 26 2023, 10:29 AM
Root_Werks   That much welding, I'd use a gas shielded MIG....   Nov 26 2023, 05:32 PM
mgarrison   I used the HF titanium flux core welder because I ...   Nov 27 2023, 12:59 PM
porschetub   Seems to be all about wire and feed control which ...   Nov 28 2023, 03:48 PM
Deusexmachina77   After much deliberation and searching, I found the...   Dec 11 2023, 08:26 AM
Spoke   After much deliberation and searching, I found th...   Dec 11 2023, 12:19 PM
930cabman   After much deliberation and searching, I found t...   Dec 11 2023, 12:26 PM
Spoke   [quote name='Spoke' post='3117343' date='Dec 11 2...   Dec 11 2023, 12:40 PM
930cabman   After much deliberation and searching, I found t...   Dec 12 2023, 02:44 PM
930cabman   "A friend with a welder and a garage" so...   Dec 11 2023, 08:50 AM
Superhawk996   Butt weld is the gold standard for panel repair. ...   Dec 11 2023, 09:07 AM
porschetub   Butt weld is the gold standard for panel repair. ...   Dec 11 2023, 01:29 PM
Geezer914   I picked up a used Sears flux core welder for ...   Dec 11 2023, 09:13 AM
MikeK   There's no shame in a lap weld if the joint is...   Dec 11 2023, 10:53 AM
Geezer914   Trace a pattern of the cut out on a piece of poste...   Dec 11 2023, 12:14 PM
Superhawk996   @porschetub Try a shrinking wheel on it to remov...   Dec 11 2023, 07:22 PM
mb911   Ok I have to pipe up a little bit here as I do thi...   Dec 12 2023, 05:15 PM
mb911   RE: Welding advice   Dec 12 2023, 05:16 PM
930cabman   Nothing short of artwork, thanks for posting. Ho...   Dec 12 2023, 07:14 PM
bkrantz   Another vote for butt welding, and you can doing i...   Dec 12 2023, 09:05 PM
Deusexmachina77   @mb911 That TIG weld is a thing of beauty. I only...   Dec 13 2023, 04:49 PM
mb911   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 13 2023, 04:56 PM
bkrantz   [b]@[url=http://www.914world.com/bbs2/index.php?...   Dec 13 2023, 08:05 PM
MikeK   [b]@[url=http://www.914world.com/bbs2/index.php?...   Dec 14 2023, 09:48 AM
mb911   [quote name='mb911' post='3117713' date='Dec 13 2...   Dec 16 2023, 01:39 PM
MikeK   Here's an alternative method for fitting and h...   Dec 14 2023, 10:10 AM
930cabman   Great advice MikeK, thanks I will making the same...   Dec 14 2023, 01:01 PM
914rrr   Is flux welding more apt to have paint adhesion is...   Dec 15 2023, 07:59 PM
930cabman   Is flux welding more apt to have paint adhesion i...   Dec 16 2023, 08:55 AM
914rrr   Is flux welding more apt to have paint adhesion ...   Dec 16 2023, 09:42 AM
mb911   [quote name='930cabman' post='3118200' date='Dec ...   Dec 16 2023, 01:37 PM
gereed75   It will also destroy the strength of the magnet A...   Dec 16 2023, 03:00 PM
mb911   It will also destroy the strength of the magnet ...   Dec 17 2023, 07:23 AM
Deusexmachina77   I cut the panel to where I thought it would lay be...   Dec 18 2023, 04:56 PM
930cabman   I cut the panel to where I thought it would lay b...   Dec 19 2023, 07:22 AM
Superhawk996   :headbanger: pretty good fit for someone that was ...   Dec 18 2023, 10:43 PM
mb911   :headbanger: pretty good fit for someone that was...   Dec 19 2023, 06:29 AM
friethmiller   I remember the one problem I always had when I sta...   Dec 19 2023, 08:51 AM
Deusexmachina77   I appreciate the encouragement and the tip about t...   Dec 19 2023, 03:35 PM
r_towle   never in one area too long....heat warps things.   Dec 19 2023, 04:35 PM
gereed75   There u go - cut and butt at its finest. Nice work...   Dec 19 2023, 05:38 PM
Deusexmachina77   Hello Friends, @[url=http://www.914world.com/bbs2...   Jan 4 2024, 09:14 AM
friethmiller   Well, that depends what you want. If you want to ...   Jan 4 2024, 09:45 AM
Superhawk996   Agree - don’t thin metal by grinding too much ...   Jan 4 2024, 09:47 AM
friethmiller   Due to all the stamping formation complexity, it ...   Jan 4 2024, 10:21 AM
mb911   The proper way would be to use epoxy primer then s...   Jan 5 2024, 05:08 PM
Deusexmachina77   That's the look I want. And you say you use be...   Jan 5 2024, 05:23 PM
mb911   That's the look I want. And you say you use b...   Jan 5 2024, 07:49 PM
Deusexmachina77   That's the look I want. And you say you use ...   Jan 5 2024, 10:08 PM
worn   That's the look I want. And you say you use b...   Jan 5 2024, 07:51 PM
mb911   That's the look I want. And you say you use ...   Jan 6 2024, 05:47 AM
mb911   this is mine finished   Jan 5 2024, 07:51 PM
mb911   RE: Welding advice   Jan 5 2024, 07:53 PM
flat4guy   Put 2 floors, a couple quarters and many other sma...   Jan 5 2024, 09:13 PM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 05:27 PM
