Welding advice, Can a cheap flux welder do what I need? |
Deusexmachina77 |
Nov 25 2023, 11:24 AM
Member Group: Members Posts: 96 Joined: 30-March 22 From: Chicago Member No.: 26,426 Region Association: Upper MidWest |
I have to weld in a new front trunk pan replacing the hole left from an AC unit. I have taken two MIG classes. Beside being a newbie, I have other limitations to consider.
I don’t have access to a 220 line. I’m inexperienced. It would cost me $1000 to have it professionally done. And I don’t want to buy a bunch of equipment for one job. Can I use a flux welder? There a couple cheap units at Harbor Freight (under $150) on sale right now. What don’t I know that I should know? Thanks (IMG:style_emoticons/default/welder.gif) |
MikeK |
Dec 14 2023, 09:48 AM
Member Group: Members Posts: 132 Joined: 15-June 23 From: 80906 Member No.: 27,418 Region Association: Rocky Mountains |
@mb911 That TIG weld is a thing of beauty. I only have access to a MIG welder and am not skilled enough to lay down beads like that. Re-reading my follow-up post, the litany of not wanting to weld from the bottom was about the lap weld. I thought I would have to do the top and the bottom. I have a pretty good mess to clean up first, so I'll see how I do with all that work first. And then I'll decide how comfortable I am with the butt weld. I usually have to do things twice. Something tells me I'll be paying a professional–eventually. Thank you everyone for your thoughts. It is a constructive discussion. I've learned a lot. (IMG:style_emoticons/default/smilie_pokal.gif) Use magnets to hold the but joint tight until it’s tacked in. I find that my arc likes to wander when I'm tacking things up with a MIG while using magnets. Maybe I'm imagining it. It also took me a couple of Winters to figure out that my welds went to shit when my shop heater turned on. Then I realized all my shielding gas was blowing away... |
Lo-Fi Version | Time is now: 6th January 2025 - 05:37 PM |
