123 Install Today - GETTING CLOSER..., PROGRESS: BAD MPS |
FlacaProductions |
Dec 14 2023, 09:50 AM
Senior Member Group: Members Posts: 1,733 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
74 2.0 D-Jet
Heading to the garage now to start the install and my main, unresolved-in-my-brain question is if i need to hook up the vacuum line that is on my current stock distributor, on the 123. |
FlacaProductions |
Dec 14 2023, 06:23 PM
Had a little moment tonight and went back out and attempted to start. No joy. Fuel pump runs as normal, cranks fine but doesn't even act like it wants to catch. Rotated distributor slowly with no luck.
Plug wires are on in correct order. New 123 coil installed as well. Large(ish) black wire to + and black/purple tach wire to - on the coil (as usual/before). Red from 123 to + black to - blue to ground. Yellow from 123 into left distributor connection/white into right - middle is open. (as looking into connector with "high point" of the female connector on top) I get bluetooth connection to app. Not sure what I don't have right but I'll maybe go back to green light setup point and double check that. |
Lo-Fi Version | Time is now: 19th September 2024 - 04:08 PM |
