Welding advice, Can a cheap flux welder do what I need? |
Deusexmachina77 |
Nov 25 2023, 11:24 AM
Member Group: Members Posts: 96 Joined: 30-March 22 From: Chicago Member No.: 26,426 Region Association: Upper MidWest |
I have to weld in a new front trunk pan replacing the hole left from an AC unit. I have taken two MIG classes. Beside being a newbie, I have other limitations to consider.
I don’t have access to a 220 line. I’m inexperienced. It would cost me $1000 to have it professionally done. And I don’t want to buy a bunch of equipment for one job. Can I use a flux welder? There a couple cheap units at Harbor Freight (under $150) on sale right now. What don’t I know that I should know? Thanks (IMG:style_emoticons/default/welder.gif) |
914rrr |
Dec 15 2023, 07:59 PM
Senior Member Group: Members Posts: 1,838 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States |
Is flux welding more apt to have paint adhesion issues vs MIG? IIRC, one of my first 914's had a what looked like a rust spot in the drivers side front fender near the bottom. When we started grinding it, we discovered it had been repaired / patched already and welded (brazed) with brass. I was told that unless you are meticulous in removing every bit of flux then then the body filler and paint wouldn't stick to it properly. Is this correct?
930cabman |
Dec 16 2023, 08:55 AM
Advanced Member Group: Members Posts: 3,806 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Is flux welding more apt to have paint adhesion issues vs MIG? IIRC, one of my first 914's had a what looked like a rust spot in the drivers side front fender near the bottom. When we started grinding it, we discovered it had been repaired / patched already and welded (brazed) with brass. I was told that unless you are meticulous in removing every bit of flux then then the body filler and paint wouldn't stick to it properly. Is this correct? Not only flux, but any contaminant. painting is all about prep and it can be anything |
914rrr |
Dec 16 2023, 09:42 AM
Is flux welding more apt to have paint adhesion issues vs MIG? IIRC, one of my first 914's had a what looked like a rust spot in the drivers side front fender near the bottom. When we started grinding it, we discovered it had been repaired / patched already and welded (brazed) with brass. I was told that unless you are meticulous in removing every bit of flux then then the body filler and paint wouldn't stick to it properly. Is this correct? Not only flux, but any contaminant. painting is all about prep and it can be anything So, is flux core welding generally a bad idea for anything that will be painted, especially if it's on an exterior body panel vs pans or trunk areas? |
mb911 |
Dec 16 2023, 01:37 PM
914 Guru Group: Members Posts: 7,391 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Is flux welding more apt to have paint adhesion issues vs MIG? IIRC, one of my first 914's had a what looked like a rust spot in the drivers side front fender near the bottom. When we started grinding it, we discovered it had been repaired / patched already and welded (brazed) with brass. I was told that unless you are meticulous in removing every bit of flux then then the body filler and paint wouldn't stick to it properly. Is this correct? Not only flux, but any contaminant. painting is all about prep and it can be anything So, is flux core welding generally a bad idea for anything that will be painted, especially if it's on an exterior body panel vs pans or trunk areas? No it will be just fine. They literally paint buildings and the frame work of sky scrapers that have been flux core welded. Just clean it properly |
Lo-Fi Version | Time is now: 6th January 2025 - 05:48 PM |
