123 Install Today - GETTING CLOSER..., PROGRESS: BAD MPS |
FlacaProductions |
Dec 14 2023, 09:50 AM
Senior Member Group: Members Posts: 1,733 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
74 2.0 D-Jet
Heading to the garage now to start the install and my main, unresolved-in-my-brain question is if i need to hook up the vacuum line that is on my current stock distributor, on the 123. |
Dave_Darling |
Dec 17 2023, 07:00 PM
914 Idiot Group: Members Posts: 15,047 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
D-Jet is open-loop; there is zero feedback from the engine about the actual mixture that is achieved.
Many of the D-Jet cars used vacuum advance and retard both. It makes sense that you could use either one on a 123 distributor. I do agree that the basics need to be re-confirmed. Double check the timing marks on the fan against the flywheel. --DD |
FlacaProductions |
Dec 17 2023, 08:25 PM
I do agree that the basics need to be re-confirmed. Double check the timing marks on the fan against the flywheel. --DD Dave - I totally agree. This is what I've been doing: On a mid-rise lift, in 5th gear, having a partner block one wheel while turning the other and watching thru the timing hole. Red mark comes thru first...and then white. That's what I'm using for TDC When the white mark is lined up, there is also a mark that appears and lines up in the transmission inspection hole. I hope someone can tell me where I'm incorrect. Please. |
Lo-Fi Version | Time is now: 19th September 2024 - 03:57 PM |
