> Stripped, Clean metal
930cabman
post Dec 18 2023, 05:52 AM
We have been using Back to Nature "Multi Strip" for over 20 years in our window restoration shop and as you can see it works well in our car shop. Available at your local HD in smallish containers. I used about a gallon for the whole car.
Shivers
post Dec 18 2023, 01:16 PM
Wow, that works pretty good. Thanks for the tip
930cabman   Stripped   Dec 18 2023, 05:52 AM
jaredmcginness   Thanks was looking for a new brand to try. Just or...   Dec 18 2023, 07:08 AM
930cabman   More It needs to be 65 degrees minimum and I g...   Dec 18 2023, 07:53 AM
Geezer914   Thanks for sharing.   Dec 18 2023, 08:16 AM
MikeK   Thanks for posting. I'll give it a try. It...   Dec 18 2023, 10:15 AM
930cabman   Thanks for posting. I'll give it a try. It...   Dec 18 2023, 10:37 AM
technicalninja   Looks like an alternate to "stinky" remo...   Dec 18 2023, 11:37 AM
930cabman   Looks like an alternate to "stinky" rem...   Dec 18 2023, 02:21 PM
Shivers   Wow, that works pretty good. Thanks for the tip   Dec 18 2023, 01:16 PM
930cabman   Not exactly why but check out the rusting under th...   Jan 1 2024, 07:17 AM
davep   Not exactly why but check out the rusting under t...   Jan 1 2024, 08:03 AM
930cabman   Not exactly why but check out the rusting under ...   Jan 1 2024, 12:14 PM
friethmiller   Not exactly why but check out the rusting under t...   Jan 1 2024, 08:45 AM
brant   The rust occurs during stripping It wasn’t unde...   Jan 1 2024, 08:42 AM
930cabman   The rust occurs during stripping It wasn’t und...   Jan 1 2024, 12:03 PM
Jett   Our garage is at a constant 71 degrees from the fl...   Jan 1 2024, 09:56 AM
mepstein   Was it original paint and primer or a respray.   Jan 1 2024, 12:29 PM
930cabman   Was it original paint and primer or a respray. ...   Jan 1 2024, 02:34 PM
technicalninja   I've found I get rust overnight it I don't...   Jan 1 2024, 01:32 PM
930cabman   First coat of epoxy primer   Jan 3 2024, 02:48 PM
friethmiller   First coat of epoxy primer Looks great! Are...   Jan 3 2024, 03:44 PM
930cabman   First coat of epoxy primer Looks great! Ar...   Jan 3 2024, 04:24 PM
nivekdodge   you would see rust like that under surfaces that ...   Jan 3 2024, 11:17 PM
930cabman   you would see rust like that under surfaces that...   Jan 4 2024, 02:14 PM
930cabman   progress and yes it's a pleasure NOT working w...   Jan 5 2024, 10:46 AM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 18th January 2025 - 08:26 PM
