> Welding advice, Can a cheap flux welder do what I need?
Deusexmachina77
post Nov 25 2023, 11:24 AM
I have to weld in a new front trunk pan replacing the hole left from an AC unit. I have taken two MIG classes. Beside being a newbie, I have other limitations to consider.
I don’t have access to a 220 line.
I’m inexperienced.
It would cost me $1000 to have it professionally done. And I don’t want to buy a bunch of equipment for one job.
Can I use a flux welder? There a couple cheap units at Harbor Freight (under $150) on sale right now. What don’t I know that I should know?
Thanks (IMG:style_emoticons/default/welder.gif)
Superhawk996
post Dec 18 2023, 10:43 PM
(IMG:style_emoticons/default/aktion035.gif) pretty good fit for someone that was going to lap weld it!!
Use a copper backer on those back wall large gaps and you’ll be fine.
Keep going. Go slow. Bounce around. Cool to the touch before adding more welds.
Deusexmachina77   Welding advice   Nov 25 2023, 11:24 AM
Shivers   Just patching the hole, absolutely. I do all sorts...   Nov 25 2023, 11:31 AM
iankarr   Get a 120v Hobart Handler. U can set it up for mig...   Nov 25 2023, 11:32 AM
Superhawk996   May I suggest you’ve asked the wrong question. ...   Nov 25 2023, 12:03 PM
930cabman   May I suggest you’ve asked the wrong question. ...   Nov 25 2023, 12:35 PM
Superhawk996   Looked up what is on sale Definately don’t get...   Nov 25 2023, 12:38 PM
rjames   Echoing the advice to look for a quality unit that...   Nov 25 2023, 01:08 PM
Deusexmachina77   Guys, Thanks everyone for really good advice. I w...   Nov 25 2023, 03:12 PM
Superhawk996   felt I didn’t know enough to evaluate the cond...   Nov 25 2023, 05:47 PM
mb911   Ugh I need to do a sticky on this. Superhawk has y...   Nov 25 2023, 07:54 PM
bkrantz   Find a friend with a welder. Or (better) find a f...   Nov 25 2023, 08:13 PM
emerygt350   I have had the titanium for 4 years now. I have u...   Nov 26 2023, 07:15 AM
IronHillRestorations   True MIG (shielding gas) is the only way to go for...   Nov 26 2023, 08:12 AM
stownsen914   As a self taught hobbyist welder, I'd have to ...   Nov 26 2023, 08:21 AM
Mayne   I have a small Titanium flux core welder that has ...   Nov 26 2023, 08:43 AM
Spoke   I don’t have access to a 220 line. I was worri...   Nov 26 2023, 08:48 AM
MikeK   I have to weld in a new front trunk pan replacing...   Nov 26 2023, 10:29 AM
Root_Werks   That much welding, I'd use a gas shielded MIG....   Nov 26 2023, 05:32 PM
mgarrison   I used the HF titanium flux core welder because I ...   Nov 27 2023, 12:59 PM
porschetub   Seems to be all about wire and feed control which ...   Nov 28 2023, 03:48 PM
Deusexmachina77   After much deliberation and searching, I found the...   Dec 11 2023, 08:26 AM
Spoke   After much deliberation and searching, I found th...   Dec 11 2023, 12:19 PM
930cabman   After much deliberation and searching, I found t...   Dec 11 2023, 12:26 PM
Spoke   [quote name='Spoke' post='3117343' date='Dec 11 2...   Dec 11 2023, 12:40 PM
930cabman   After much deliberation and searching, I found t...   Dec 12 2023, 02:44 PM
930cabman   "A friend with a welder and a garage" so...   Dec 11 2023, 08:50 AM
Superhawk996   Butt weld is the gold standard for panel repair. ...   Dec 11 2023, 09:07 AM
porschetub   Butt weld is the gold standard for panel repair. ...   Dec 11 2023, 01:29 PM
Geezer914   I picked up a used Sears flux core welder for ...   Dec 11 2023, 09:13 AM
MikeK   There's no shame in a lap weld if the joint is...   Dec 11 2023, 10:53 AM
Geezer914   Trace a pattern of the cut out on a piece of poste...   Dec 11 2023, 12:14 PM
Superhawk996   @porschetub Try a shrinking wheel on it to remov...   Dec 11 2023, 07:22 PM
mb911   Ok I have to pipe up a little bit here as I do thi...   Dec 12 2023, 05:15 PM
mb911   RE: Welding advice   Dec 12 2023, 05:16 PM
930cabman   Nothing short of artwork, thanks for posting. Ho...   Dec 12 2023, 07:14 PM
bkrantz   Another vote for butt welding, and you can doing i...   Dec 12 2023, 09:05 PM
Deusexmachina77   @mb911 That TIG weld is a thing of beauty. I only...   Dec 13 2023, 04:49 PM
mb911   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 13 2023, 04:56 PM
bkrantz   [b]@[url=http://www.914world.com/bbs2/index.php?...   Dec 13 2023, 08:05 PM
MikeK   [b]@[url=http://www.914world.com/bbs2/index.php?...   Dec 14 2023, 09:48 AM
mb911   [quote name='mb911' post='3117713' date='Dec 13 2...   Dec 16 2023, 01:39 PM
MikeK   Here's an alternative method for fitting and h...   Dec 14 2023, 10:10 AM
930cabman   Great advice MikeK, thanks I will making the same...   Dec 14 2023, 01:01 PM
914rrr   Is flux welding more apt to have paint adhesion is...   Dec 15 2023, 07:59 PM
930cabman   Is flux welding more apt to have paint adhesion i...   Dec 16 2023, 08:55 AM
914rrr   Is flux welding more apt to have paint adhesion ...   Dec 16 2023, 09:42 AM
mb911   [quote name='930cabman' post='3118200' date='Dec ...   Dec 16 2023, 01:37 PM
gereed75   It will also destroy the strength of the magnet A...   Dec 16 2023, 03:00 PM
mb911   It will also destroy the strength of the magnet ...   Dec 17 2023, 07:23 AM
Deusexmachina77   I cut the panel to where I thought it would lay be...   Dec 18 2023, 04:56 PM
930cabman   I cut the panel to where I thought it would lay b...   Dec 19 2023, 07:22 AM
Superhawk996   :headbanger: pretty good fit for someone that was ...   Dec 18 2023, 10:43 PM
mb911   :headbanger: pretty good fit for someone that was...   Dec 19 2023, 06:29 AM
friethmiller   I remember the one problem I always had when I sta...   Dec 19 2023, 08:51 AM
Deusexmachina77   I appreciate the encouragement and the tip about t...   Dec 19 2023, 03:35 PM
r_towle   never in one area too long....heat warps things.   Dec 19 2023, 04:35 PM
gereed75   There u go - cut and butt at its finest. Nice work...   Dec 19 2023, 05:38 PM
Deusexmachina77   Hello Friends, @[url=http://www.914world.com/bbs2...   Jan 4 2024, 09:14 AM
friethmiller   Well, that depends what you want. If you want to ...   Jan 4 2024, 09:45 AM
Superhawk996   Agree - don’t thin metal by grinding too much ...   Jan 4 2024, 09:47 AM
friethmiller   Due to all the stamping formation complexity, it ...   Jan 4 2024, 10:21 AM
mb911   The proper way would be to use epoxy primer then s...   Jan 5 2024, 05:08 PM
Deusexmachina77   That's the look I want. And you say you use be...   Jan 5 2024, 05:23 PM
mb911   That's the look I want. And you say you use b...   Jan 5 2024, 07:49 PM
Deusexmachina77   That's the look I want. And you say you use ...   Jan 5 2024, 10:08 PM
worn   That's the look I want. And you say you use b...   Jan 5 2024, 07:51 PM
mb911   That's the look I want. And you say you use ...   Jan 6 2024, 05:47 AM
mb911   this is mine finished   Jan 5 2024, 07:51 PM
mb911   RE: Welding advice   Jan 5 2024, 07:53 PM
flat4guy   Put 2 floors, a couple quarters and many other sma...   Jan 5 2024, 09:13 PM
17 User(s) are reading this topic (17 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 05:43 PM
