123 Install Today - GETTING CLOSER..., PROGRESS: BAD MPS |
FlacaProductions |
Dec 14 2023, 09:50 AM
Senior Member Group: Members Posts: 1,733 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
74 2.0 D-Jet
Heading to the garage now to start the install and my main, unresolved-in-my-brain question is if i need to hook up the vacuum line that is on my current stock distributor, on the 123. |
FlacaProductions |
Dec 21 2023, 09:53 AM
One thing that you mentioned to me, Ed was to disconnect everything from the coil, run a line direct from + side of the battery to the + side of the coil and then connect the red from the 123 to the + at the coil and the black from the 123 to - at the coil. Connect the blue wire from 123 to ground.
This circumvents the primary circuit and if it fires in this configuration, indicates too much resistance in the primary. It's on the list - didn't do it originally as I always felt I was "this close" by doing the standard setup. |
Lo-Fi Version | Time is now: 19th September 2024 - 03:35 PM |
