> brake upgrade, BMW Callipers
Petepat
post Dec 19 2023, 06:04 PM
So I've looked at the links using Boxer callipers and it looks quite complicated where as some where I read one can do a straight swop using BMW callipers. Has anyone done this and was it an improvement? Yours thoughts in this direction welcomed.
post Dec 19 2023, 08:50 PM
914-6 GT in waiting
You can use bmw calipers on 914-4 struts. Alfa and M calipers require 3” - 914-6/911 struts. Boxster brake calipers require 3 1/2” struts & adaptors.
mate914
post Dec 21 2023, 08:00 PM
Matt
QUOTE(mepstein @ Dec 19 2023, 09:50 PM) *
@mepstein
Guru of Porsche wisdom. What spacing is a 3.0 strut?
Matt (IMG:style_emoticons/default/flag.gif)
Petepat   brake upgrade   Dec 19 2023, 06:04 PM
technicalninja   I'm doing exactly this on the 75 I am resurrec...   Dec 19 2023, 07:13 PM
burton73   Alpha calipers on a 914-4 front suspension with 91...   Dec 19 2023, 08:43 PM
mepstein   You can use bmw calipers on 914-4 struts. Alfa and...   Dec 19 2023, 08:50 PM
burton73   You can use bmw calipers on 914-4 struts. Alfa an...   Dec 19 2023, 09:01 PM
mate914   You can use bmw calipers on 914-4 struts. Alfa an...   Dec 21 2023, 08:00 PM
mepstein   [quote name='mepstein' post='3118933' date='Dec 1...   Dec 21 2023, 08:23 PM
Ishley   I have BMW brakes on my 72 914-4. It came with the...   Dec 19 2023, 09:35 PM
rjames   So I've looked at the links using Boxer calli...   Dec 19 2023, 09:58 PM
mepstein   So I've looked at the links using Boxer call...   Dec 19 2023, 11:09 PM
infraredcalvin   Hmmm from boxster to bmw brakes that’s a huge sw...   Dec 19 2023, 10:13 PM
Geezer914   I did a BMW front caliper swap with a 19mm master ...   Dec 20 2023, 07:05 AM
brant   The conversion to 5 lugs also gives you a vented r...   Dec 20 2023, 07:52 AM
914Sixer   GO to Classic Section and DO your homework. Cover...   Dec 20 2023, 08:15 AM
Petepat   Well thanks guys for all the input, I just want th...   Dec 21 2023, 06:14 PM
914Sixer   Yes you can lock them. You cannot compare to ABS ...   Dec 21 2023, 06:28 PM
Superhawk996   Yes you can lock them. You cannot compare to ABS...   Dec 21 2023, 06:46 PM
Superhawk996   Well if the calipers were painted red . . . They a...   Dec 21 2023, 06:45 PM
Shivers   I can share what worked well with mine. I put stee...   Dec 21 2023, 07:48 PM
14 User(s) are reading this topic (14 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 11th February 2025 - 01:34 AM
