vjb206 |
Newbie ![]() Group: Members Posts: 32 Joined: 23-December 19 From: New Jersey Member No.: 23,760 Region Association: North East States ![]() |
Hey folks! I've got...
I started by measuring all of the the main journals on the crank and I got a range from 2.358” - 2.360” (I used a digital caliper and I'm pretty sure I did this correctly). Then I “dry-fit” Silverline STD/STD main bearings into the case (sans crank), torqued everything down, and got 0.003” in radial play (I used a cylinder bore dial gauge for the first time, and I think I did it correctly). The spec-sheet says radial play should be between 0.06” - 0.10” (0.03” - 0.09” for #2); and I have 0.003." I'm a MINIMUM of 0.057" off, is that normal? What's my next step?
vjb206 |
Measurements are in MM. Excuse me while I––––
(IMG:http://www.914world.com/bbs2/uploads_offsite/media4.giphy.com-23760-1702315305.1.gif) |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,005 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Measurements are in MM. Excuse me while I–––– (IMG:http://www.914world.com/bbs2/uploads_offsite/media4.giphy.com-23760-1702315305.1.gif) (IMG:style_emoticons/default/lol-2.gif) Trust me I've done that too. Just gotta' be sure you know what the spec is and how its measured. Here's a tip: If the measurement is only two significant digits (.06) it's probably in metric. Three or Four significant digits (.024 or .02364) is probably inches. This is because a miilimeter is such a small fraction of an inch, it only takes two significant digits to get you into very small numbers with high precision. |
vjb206 |
Measurements are in MM. Excuse me while I–––– (IMG:http://www.914world.com/bbs2/uploads_offsite/media4.giphy.com-23760-1702315305.1.gif) (IMG:style_emoticons/default/lol-2.gif) Trust me I've done that too. Just gotta' be sure you know what the spec is and how its measured. Here's a tip: If the measurement is only two significant digits (.06) it's probably in metric. Three or Four significant digits (.024 or .02364) is probably inches. This is because a miilimeter is such a small fraction of an inch, it only takes two significant digits to get you into very small numbers with high precision. Hey folks - Merry Christmas and a Happy New Year! I'm back at measuring and have some more accurate figures (see below on method). Bottom-line is that for all of the bearings I have either zero clearance (like literally 0.00mm radial play), or at most I have 0.03mm. (IMG:http://www.914world.com/bbs2/uploads_offsite/media.giphy.com-23760-1703704167.1.gif) Bearings as follows:
@Superhawk996 , @Montreal914 , @930cabman : Assuming this is normal, my next step will be to call my friendly neighborhood machinist to take the required amount of material off each bearing so that the tolerance sits on the low end of the radial play spec. Does this sound right to you? Thanks for everyone's input so far, I truly appreciate it. ///// Process /////
Lo-Fi Version | Time is now: 26th April 2025 - 08:04 PM |
