| vjb206 |
Dec 11 2023, 08:42 AM
Newbie ![]() Group: Members Posts: 32 Joined: 23-December 19 From: New Jersey Member No.: 23,760 Region Association: North East States |
Hey folks! I've got...
I started by measuring all of the the main journals on the crank and I got a range from 2.358” - 2.360” (I used a digital caliper and I'm pretty sure I did this correctly). Then I “dry-fit” Silverline STD/STD main bearings into the case (sans crank), torqued everything down, and got 0.003” in radial play (I used a cylinder bore dial gauge for the first time, and I think I did it correctly). The spec-sheet says radial play should be between 0.06” - 0.10” (0.03” - 0.09” for #2); and I have 0.003." I'm a MINIMUM of 0.057" off, is that normal? What's my next step?
| technicalninja |
Dec 29 2023, 01:59 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
@Superhawk996
I'm guessing you're like me and by the time the PG is being used we already know what our clearances will be... Both you and I will always be able to overcome roadblocks in the technical world as we have the "gotta rip it apart" mental illness! I've had it forever. I'll have active projects in process when I die. I'd bet you are similar. And here's yet another shortcoming in the horizontally opposed engine design... All my 4/6/8 cylinder builds that are not opposed are capable at PGing all bearings main and rod together with a single crankshaft install. No blocking or limiting rotation needed on anything... This is one of the reasons I advised the OP "stop and learn" as enough "T4s do it this way/everyone else does not" exist to be critical. The T4 is not really harder than others to rebuild, just has some "non-standard" strangeness to understand. Today, with all the different oil pump diameters, I'll check my cases for proper oil pump bore/clearance as well as main and cam bores. I've NEVER done that on ANYTHING else in my life! If I have to have cases line bored, I'll request a specific oil pump bore diameter based on the oil pump I purchase. This is weird in my book... Edit: WOW! that crank is dirty for taking measurements. I hope your cleaning off each individual journal before... (IMG:style_emoticons/default/beerchug.gif) |
vjb206 2270 Build thread Dec 11 2023, 08:42 AM
930cabman Did you get the rotating components balanced?
Not... Dec 11 2023, 09:09 AM
Superhawk996 Hopefully this doesn’t come off as condescending... Dec 11 2023, 09:32 AM
Montreal914 To measure the crank, I would use a micrometer, no... Dec 11 2023, 09:51 AM
vjb206 Great responses! Thank you for the engagement.... Dec 11 2023, 10:47 AM
Montreal914 Van Svenson still has his YouTube videos on his ch... Dec 11 2023, 10:58 AM
Superhawk996 Regarding info in the link you provided - all thos... Dec 11 2023, 10:59 AM
vjb206 Measurements are in MM. Excuse me while I–––... Dec 11 2023, 11:21 AM
Superhawk996
Measurements are in MM. Excuse me while I––... Dec 11 2023, 11:48 AM
vjb206
Measurements are in MM. Excuse me while I––... Dec 27 2023, 01:09 PM
930cabman hate to ask, but have you built engines in the pas... Dec 11 2023, 11:52 AM
rhodyguy I did not note this in the intro. Remove, tap and ... Dec 11 2023, 12:56 PM
rhodyguy Admin delete please. Dec 11 2023, 12:58 PM
914sgofast2 I would suggest you read the post named "Chea... Dec 11 2023, 01:08 PM
technicalninja
I would suggest you read the post named "Che... Dec 11 2023, 01:41 PM
technicalninja I'm a big believer when making a "compari... Dec 27 2023, 01:48 PM
mepstein “: Assuming this is normal, my next step will be... Dec 27 2023, 01:56 PM
technicalninja I'd also convert everything to US standard ins... Dec 27 2023, 02:05 PM
Superhawk996 Yeah - hit pause. Something is wacko - probably m... Dec 27 2023, 04:34 PM
Superhawk996 Also I want to take a second and commend you for l... Dec 27 2023, 04:58 PM
technicalninja :agree: :agree: :agree: :agree: :agree:
Sup... Dec 27 2023, 05:24 PM
cgnj I built my motor in around y2k. The choices were V... Dec 27 2023, 06:35 PM
vjb206 Again, really, really great advice. Thank you @[u... Dec 28 2023, 03:52 PM
Superhawk996
So I called my local machinist and he said that ... Dec 28 2023, 07:47 PM
technicalninja Google search "how to properly use Plasti-gau... Dec 28 2023, 04:36 PM
technicalninja I have maybe a better suggestion for you right now... Dec 28 2023, 05:53 PM
Superhawk996 Duplicate Dec 28 2023, 08:13 PM
Superhawk996
Purchase a type 4 rebuild manual. I don't kn... Dec 28 2023, 08:15 PM
Superhawk996 I should have been more clear. You can only use P... Dec 28 2023, 07:31 PM
cgnj @[url=http://www.914world.com/bbs2/index.php?showu... Dec 28 2023, 08:05 PM
Eric_Ciampa First time engine builder here. Building a 2270 an... Dec 28 2023, 11:40 PM
technicalninja That's the way...
Plasti-gauge can only be u... Dec 29 2023, 01:45 AM
Superhawk996
It's HARD to properly torque up a rod without... Dec 29 2023, 08:23 AM
Superhawk996
And here's yet another shortcoming in the ... Dec 30 2023, 01:20 AM
Jack Standz
[b]@[url=http://www.914world.com/bbs2/index.php?s... Dec 30 2023, 02:40 PM
Front yard mechanic Holy cow if Vbj listens to all this expert advice ... Dec 29 2023, 07:02 PM
Superhawk996
Holy cow if Vbj listens to all this expert advice... Dec 30 2023, 01:45 AM
vjb206 Ok we're in business and you guys are to thank... Dec 29 2023, 07:26 PM
Montreal914
Next step: More measuring, reading, and finding a... Dec 30 2023, 01:21 PM
930cabman Two comments, hoping you removed material from the... Dec 29 2023, 08:16 PM
Superhawk996 :trophy:
Congrats - while it’s apart don’t ... Dec 29 2023, 09:06 PM
technicalninja Even today I'll make three distinct measuremen... Dec 29 2023, 10:04 PM
technicalninja I've read many of the oil pressure/problems wi... Dec 30 2023, 03:19 PM
technicalninja Target Down!
This is why I get into threads.
T... Dec 30 2023, 04:34 PM
Superhawk996 I started a T4 pump thread a while back but have n... Dec 30 2023, 05:19 PM
technicalninja Life gets in the way...
Just before we moved to G... Dec 30 2023, 05:47 PM
Jack Standz https://pmbperformance.com/products/jaycee-...w-oi... Dec 31 2023, 09:31 AM
Montreal914 Jorge (George) at European Motor Works in Hawthorn... Dec 31 2023, 11:37 AM
technicalninja @Jack Standz
Thank you for posting!
Once ag... Dec 31 2023, 11:40 AM
technicalninja
Jorge (George) at European Motor Works in Hawthor... Dec 31 2023, 11:45 AM
Superhawk996 Ah - the link to the Samba T4 pump rebuild is as ... Dec 31 2023, 12:17 PM
technicalninja
Ah - the link to the Samba T4 pump rebuild is as... Dec 31 2023, 02:18 PM
Superhawk996 I’m not going to comment too much on the Tangeri... Dec 31 2023, 02:41 PM
technicalninja You might look closer at that valve...
I was EXAC... Dec 31 2023, 03:36 PM
cgnj @vjb206
This is a rod modification you may want ... Jan 1 2024, 03:10 PM
technicalninja Just looked through that. Thanks, cgnj!
Rod m... Jan 1 2024, 04:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 21st September 2026 - 12:15 PM |
