> Hard foam under carpet on PS at bulkhead?
DC_neun_vierzehn
post Dec 25 2023, 02:20 PM
I have an early '73 2.0 with a build date 12/72.
I believe my 914 should have the molded hard foam under the carpet in the passenger side footwell at the bulkhead. I'm exploring the idea of putting a small subwoofer in that piece of foam. When I pull the carpet back in the footwell it's just the metal firewall. There's no foam there.
Maybe it was removed at some point?
In a parts lot I bought a while back, there was piece of hard molded foam that I assumed was for the footwell. However, when I pull the carpet back and try to put the foam there it does not seem to fit that space.
Do I need to remove the speaker unit in that footwell and/or the center console to get this piece of foam in that space? Is that why it's not wanting to fit?
Or do I have the wrong year foam?
Is something else the issue?
JmuRiz
post Dec 28 2023, 03:47 PM
I still have mine attached to the OG carpet...not going to use either if you need a photo...I'm local-ish too.
DC_neun_vierzehn
post Dec 29 2023, 04:41 PM
QUOTE(JmuRiz @ Dec 28 2023, 04:47 PM) *
@JmuRiz appreciate that kind offer, but I removed the speaker pod and all of the carpeting on the PS ... and the foam fit snug as a bug.
I then moved on to cutting out a cavity for the sub like the one in this thread. I'm going to wait to hook it up until I have solved a couple of electrical gremlins (first things, first).
Thanks again for the offer.
- Lo-Fi Version Time is now: 22nd November 2024 - 10:08 AM
