vjb206 |
Newbie ![]() Group: Members Posts: 32 Joined: 23-December 19 From: New Jersey Member No.: 23,760 Region Association: North East States ![]() |
Hey folks! I've got...
I started by measuring all of the the main journals on the crank and I got a range from 2.358” - 2.360” (I used a digital caliper and I'm pretty sure I did this correctly). Then I “dry-fit” Silverline STD/STD main bearings into the case (sans crank), torqued everything down, and got 0.003” in radial play (I used a cylinder bore dial gauge for the first time, and I think I did it correctly). The spec-sheet says radial play should be between 0.06” - 0.10” (0.03” - 0.09” for #2); and I have 0.003." I'm a MINIMUM of 0.057" off, is that normal? What's my next step?
Front yard mechanic |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,317 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None ![]() ![]() |
Holy cow if Vbj listens to all this expert advice it will be 20 years before he gets to drive the thing not everyone is a premadona. I say build it fill it with oil and run the crap out of it (IMG:style_emoticons/default/confused24.gif)
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,005 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Holy cow if Vbj listens to all this expert advice it will be 20 years before he gets to drive the thing not everyone is a premadona. I say build it fill it with oil and run the crap out of it (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/idea.gif) Or . . . Don’t fill it with oil and run the crap out of it. Could end in the same result. (IMG:style_emoticons/default/blowup.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 26th April 2025 - 08:36 PM |
