> 2270 Build thread, Looking forward to making all of the mistakes!
vjb206
post Dec 11 2023, 08:42 AM
Hey folks! I've got...
  • Case halves from an old 1.7 (cleaned as best I could)
  • 2270 crank + P&C kit
  • #163/86b Web Cam
  • 2.0 heads with 44X36 valves, where I'll be installing dual springs and 38mm exhaust valves
  • Upgraded oil pump and other goodies
So my first question for the community has to do with ensuring the rotating mass is spinning freely/correctly…
I started by measuring all of the the main journals on the crank and I got a range from 2.358” - 2.360” (I used a digital caliper and I'm pretty sure I did this correctly).
Then I “dry-fit” Silverline STD/STD main bearings into the case (sans crank), torqued everything down, and got 0.003” in radial play (I used a cylinder bore dial gauge for the first time, and I think I did it correctly).
The spec-sheet says radial play should be between 0.06” - 0.10” (0.03” - 0.09” for #2); and I have 0.003." I'm a MINIMUM of 0.057" off, is that normal? What's my next step?
  1. Stop pretending I know what I'm doing and take it to a machinist for test-fitting and honing (I'd like to keep cost down so this is my less preferred option)
  2. DIY: hone 0.06" off all bearings (what's the right honing tool / approach here?)
  3. Order different bearings (if so, which?)
Superhawk996
post Dec 31 2023, 12:17 PM
Ah - the link to the Samba T4 pump rebuild is as in my thread. The author does a great job documenting a T4 pump rebuild.
https://www.thesamba.com/vw/forum/viewtopic.php?t=699156
I have a mill and would use a single point carbide drill capable of easily drilling the case hardened idler shaft so I would pin it a little differently but the method outlined here is perfectly plausible for those with only a drill press.
I didn’t touch on it in my thread but the main problem with larger gears like 30mm is that too much pressure will cause the oil cooler to bypass. This in turn creates overheating.
If running an auxiliary cooler with long hose lengths to the front of the car and back plus restriction of a an external thermostat - the 30mm pump would be fine.
vjb206   2270 Build thread   Dec 11 2023, 08:42 AM
930cabman   Did you get the rotating components balanced? Not...   Dec 11 2023, 09:09 AM
Superhawk996   Hopefully this doesn’t come off as condescending...   Dec 11 2023, 09:32 AM
Montreal914   To measure the crank, I would use a micrometer, no...   Dec 11 2023, 09:51 AM
vjb206   Great responses! Thank you for the engagement....   Dec 11 2023, 10:47 AM
Montreal914   Van Svenson still has his YouTube videos on his ch...   Dec 11 2023, 10:58 AM
Superhawk996   Regarding info in the link you provided - all thos...   Dec 11 2023, 10:59 AM
vjb206   Measurements are in MM. Excuse me while I–––...   Dec 11 2023, 11:21 AM
Superhawk996   Measurements are in MM. Excuse me while I––...   Dec 11 2023, 11:48 AM
vjb206   Measurements are in MM. Excuse me while I––...   Dec 27 2023, 01:09 PM
930cabman   hate to ask, but have you built engines in the pas...   Dec 11 2023, 11:52 AM
rhodyguy   I did not note this in the intro. Remove, tap and ...   Dec 11 2023, 12:56 PM
rhodyguy   Admin delete please.   Dec 11 2023, 12:58 PM
914sgofast2   I would suggest you read the post named "Chea...   Dec 11 2023, 01:08 PM
technicalninja   I would suggest you read the post named "Che...   Dec 11 2023, 01:41 PM
technicalninja   I'm a big believer when making a "compari...   Dec 27 2023, 01:48 PM
mepstein   “: Assuming this is normal, my next step will be...   Dec 27 2023, 01:56 PM
technicalninja   I'd also convert everything to US standard ins...   Dec 27 2023, 02:05 PM
Superhawk996   Yeah - hit pause. Something is wacko - probably m...   Dec 27 2023, 04:34 PM
Superhawk996   Also I want to take a second and commend you for l...   Dec 27 2023, 04:58 PM
technicalninja   :agree: :agree: :agree: :agree: :agree: Sup...   Dec 27 2023, 05:24 PM
cgnj   I built my motor in around y2k. The choices were V...   Dec 27 2023, 06:35 PM
vjb206   Again, really, really great advice. Thank you @[u...   Dec 28 2023, 03:52 PM
Superhawk996   So I called my local machinist and he said that ...   Dec 28 2023, 07:47 PM
technicalninja   Google search "how to properly use Plasti-gau...   Dec 28 2023, 04:36 PM
technicalninja   I have maybe a better suggestion for you right now...   Dec 28 2023, 05:53 PM
Superhawk996   Duplicate   Dec 28 2023, 08:13 PM
Superhawk996   Purchase a type 4 rebuild manual. I don't kn...   Dec 28 2023, 08:15 PM
Superhawk996   I should have been more clear. You can only use P...   Dec 28 2023, 07:31 PM
cgnj   @[url=http://www.914world.com/bbs2/index.php?showu...   Dec 28 2023, 08:05 PM
Eric_Ciampa   First time engine builder here. Building a 2270 an...   Dec 28 2023, 11:40 PM
technicalninja   That's the way... Plasti-gauge can only be u...   Dec 29 2023, 01:45 AM
Superhawk996   It's HARD to properly torque up a rod without...   Dec 29 2023, 08:23 AM
technicalninja   @Superhawk996 I'm guessing you're like m...   Dec 29 2023, 01:59 PM
Superhawk996   And here's yet another shortcoming in the ...   Dec 30 2023, 01:20 AM
Jack Standz   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 30 2023, 02:40 PM
Front yard mechanic   Holy cow if Vbj listens to all this expert advice ...   Dec 29 2023, 07:02 PM
Superhawk996   Holy cow if Vbj listens to all this expert advice...   Dec 30 2023, 01:45 AM
vjb206   Ok we're in business and you guys are to thank...   Dec 29 2023, 07:26 PM
Montreal914   Next step: More measuring, reading, and finding a...   Dec 30 2023, 01:21 PM
930cabman   Two comments, hoping you removed material from the...   Dec 29 2023, 08:16 PM
Superhawk996   :trophy: Congrats - while it’s apart don’t ...   Dec 29 2023, 09:06 PM
technicalninja   Even today I'll make three distinct measuremen...   Dec 29 2023, 10:04 PM
technicalninja   I've read many of the oil pressure/problems wi...   Dec 30 2023, 03:19 PM
technicalninja   Target Down! This is why I get into threads. T...   Dec 30 2023, 04:34 PM
Superhawk996   I started a T4 pump thread a while back but have n...   Dec 30 2023, 05:19 PM
technicalninja   Life gets in the way... Just before we moved to G...   Dec 30 2023, 05:47 PM
Jack Standz   https://pmbperformance.com/products/jaycee-...w-oi...   Dec 31 2023, 09:31 AM
Montreal914   Jorge (George) at European Motor Works in Hawthorn...   Dec 31 2023, 11:37 AM
technicalninja   @Jack Standz Thank you for posting! Once ag...   Dec 31 2023, 11:40 AM
technicalninja   Jorge (George) at European Motor Works in Hawthor...   Dec 31 2023, 11:45 AM
Superhawk996   Ah - the link to the Samba T4 pump rebuild is as ...   Dec 31 2023, 12:17 PM
technicalninja   Ah - the link to the Samba T4 pump rebuild is as...   Dec 31 2023, 02:18 PM
Superhawk996   I’m not going to comment too much on the Tangeri...   Dec 31 2023, 02:41 PM
technicalninja   You might look closer at that valve... I was EXAC...   Dec 31 2023, 03:36 PM
cgnj   @vjb206 This is a rod modification you may want ...   Jan 1 2024, 03:10 PM
technicalninja   Just looked through that. Thanks, cgnj! Rod m...   Jan 1 2024, 04:35 PM
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th April 2025 - 08:26 PM
