mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,963 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
So I am helping a member put brakes on his 914-6 conversion and then put carbs on it. He previously has a poor working sniper setup. It ran ok prior according to him. Then they switched to a 123 dizzy and removed the MSD ignition and then took to a tuner prior to my part. It ran much worse once the 123/MSD removal. The owner decided he was done with his sniper setup and asked me to put carbs on. I did that and for the life of me we can’t get it to run right. Starts pretty easy and idles decent. When I go to throttle up by hand on the cross bar it doesn’t want to accept all the fuel and shoots quite a bit back up through the horns. My suspicion is a major timing issue as in 180 off. The carbs are new and setup up by Dave Chenny so very confident in them. Seeing as the car is 1.5 hours away each visit I am looking for a bit coaching here. What else should I be looking at? The engine is a fresh 2.7 not built by me with about 1000 miles on it.
Help with some ideas please. |
Retroracer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest ![]() ![]() |
So I am helping ...The owner decided he was done with his sniper setup and asked me to put carbs on. I did that and for the life of me we can’t get it to run right. Starts pretty easy and idles decent. When I go to throttle up by hand on the cross bar it doesn’t want to accept all the fuel and shoots quite a bit back up through the horns. My suspicion is a major timing issue as in 180 off. The carbs are new and setup up by Dave Chenny so very confident in them. Seeing as the car is 1.5 hours away each visit I am looking for a bit coaching here. What else should I be looking at? The engine is a fresh 2.7 not built by me with about 1000 miles on it. Help with some ideas please. Ben - you don't state what fuel pressure / pump / regulator set up the car is running. Presumably (I've never used one, but) the sniper EFI needed a much higher fuel pressure feed than the carbs (probs at least 45 PSI or higher) - did you somehow reduce this to <5psi for the carbs? If not, likely the floats are probably being overwhelmed at idle and too much fuel is sloshing in. Also: if Dave C rebuilt the carbs I'm guessing they are Zeniths - so will require 3.5 - 4.5 PSI for decent running. Hopefully he bored out the Venturis and rejetted for the 2.7 too... Hope the above is useful, - Tony |
Lo-Fi Version | Time is now: 25th June 2024 - 05:24 PM |
