914-6 Wiring Schematic, Anyone got a better one than this |
SixerJ |
Nov 6 2016, 08:05 AM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
Hi Guys,
I've been trawling 914 World and the internet generally for a cleaner copy of the attached for my '70 -6 I have found links to this http://www.zapfenterprises.com/orderInfo.html which is the only colour option in existence, as at would appear the factory never bothered & probably will order in the fullness of time I've also managed to find what I think is a diagram for the '72 six on Jeff's site here http://bowlsby.net/914/Classic/zMan_1970-7...2Supplement.pdf I've got an electronic copy of the workshop manuals (I'm assuming the electrical section is complete), no luck there either. I've also taken a peep at my friends set of paper manuals, which had the attached as a photocopy slipped in This diagram seems to be the holy grail of wiring diagrams (IMG:style_emoticons/default/confused24.gif) & I would appear to have run into a wall for the early cars (IMG:style_emoticons/default/headbang.gif) & any help greatly appreciated Thanks Jon Porsche_914_6_Black_and_White_Wiring_Diagram_Scan_V1.pdf ( 866.73k ) Number of downloads: 714 |
930cabman |
Jan 5 2024, 01:09 PM
Advanced Member Group: Members Posts: 3,708 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
How different from the /4 can it be?
mepstein |
Jan 5 2024, 04:36 PM
914-6 GT in waiting Group: Members Posts: 19,608 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
ClayPerrine |
Jan 7 2024, 08:31 AM
Life's been good to me so far..... Group: Admin Posts: 15,906 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
How different from the /4 can it be? Not much from an early 4. Mostly ignition switch and windshield washer. And of course the engine harness is completely different. The connection to the relay board is different, there is no wiring for the wiper motor other than a power wire, there is wiring for an electric washer pump, the turn signal wiring is different because the six uses a 911 turn signal switch, the headlight wiring is different because the six does not use a high beam relay, and as previously mentioned, the ignition switch is completely different. There is enough stuff different to make it require a completely different wiring diagram. |
Lo-Fi Version | Time is now: 28th November 2024 - 07:44 AM |
