> Engine number missing on my 75 914 2.0
Junioren
post Jan 9 2024, 05:52 AM
Good morning to all of you readers.
I recently imported a 75 2.0 914. VIN and chassis numbers have been located and seem in order, however I am unable to find the engine number in its usual spot.
What could be explanations for having an engine without an engine number? When engines were replaced by VW/Porsche, would these new engines possibly have no number on them?
Thanks,
Raf (from Luxembourg/Europe)
dr914@autoatlanta.com
post Jan 9 2024, 09:58 AM
did you look down in the canyon between the oil filler and the front impeller housing?
QUOTE(Junioren @ Jan 9 2024, 04:52 AM) *
Thanks,
Junioren
post Jan 9 2024, 03:37 PM
That is indeed where I checked and was expecting it, but no.
QUOTE(dr914@autoatlanta.com @ Jan 9 2024, 04:58 PM) *
Thanks,
Junioren   Engine number missing on my 75 914 2.0   Jan 9 2024, 05:52 AM
bdstone914   Good morning to all of you readers. I recently i...   Jan 9 2024, 06:22 AM
Shivers   I had to buy a new case after a disaster. It also ...   Jan 9 2024, 07:37 AM
Junioren   Thanks for the info, much appreciated. So in such ...   Jan 9 2024, 07:59 AM
jhynesrockmtn   Thanks for the info, much appreciated. So in such...   Jan 9 2024, 08:47 AM
Superhawk996   Did you check up at front of engine by the oil fil...   Jan 9 2024, 08:57 AM
davep   There are three locations for the engine serial #....   Jan 9 2024, 09:27 AM
dr914@autoatlanta.com   did you look down in the canyon between the oil fi...   Jan 9 2024, 09:58 AM
Junioren   That is indeed where I checked and was expecting i...   Jan 9 2024, 03:37 PM
dr914@autoatlanta.com   75 76 air pump 2.0 engine for the 49 states but sh...   Jan 10 2024, 09:06 AM
Junioren   A sticker on the engine provides the engine family...   Jan 9 2024, 03:32 PM
wonkipop   A sticker on the engine provides the engine famil...   Jan 9 2024, 08:10 PM
Junioren   Hello guys, I just dump the information I have bu...   Jan 9 2024, 04:04 PM
wonkipop   Hello guys, I just dump the information I have b...   Jan 9 2024, 07:29 PM
fiacra   I thought all EA code engines were 1.7? Can you p...   Jan 9 2024, 06:48 PM
emerygt350   Show us the heads! A 1.7 block is fine if the...   Jan 9 2024, 08:05 PM
JeffBowlsby   Missing a couple important details to know what yo...   Jan 9 2024, 08:08 PM
Junioren   Missing a couple important details to know what y...   Jan 10 2024, 09:03 AM
davep   EA013495 should be an October 1971 engine, but tha...   Jan 9 2024, 09:26 PM
wonkipop   EA013495 should be an October 1971 engine, but th...   Jan 10 2024, 01:48 AM
nditiz1   One thought, it could be a 912E case. They never ...   Jan 10 2024, 07:55 AM
JeffBowlsby   Considering all the above, looks like you started ...   Jan 10 2024, 10:27 AM
Junioren   Considering all the above, looks like you started...   Jan 11 2024, 02:16 PM
JeffBowlsby   Those are capped off air injectors, supplied by yo...   Jan 11 2024, 03:21 PM
rjames   What's with the plugged adapter? Looks like it...   Jan 11 2024, 03:38 PM
wonkipop   What's with the plugged adapter? Looks like i...   Jan 11 2024, 06:16 PM
wonkipop   What's with the plugged adapter? Looks like i...   Jan 11 2024, 07:02 PM
emerygt350   We need to see the ports on the plenum. Looks lik...   Jan 11 2024, 04:04 PM
Junioren   Thanks for all your help on previous questions. ...   Jan 12 2024, 03:20 PM
Shivers   Thanks for all your help on previous questions. ...   Jan 13 2024, 09:27 AM
emerygt350   And unless it is a bus 2.0 the intakes on the Pors...   Jan 13 2024, 10:35 AM
Dave_Darling   All of the Type IV motors have bottom-side exhaust...   Jan 15 2024, 02:28 AM
emerygt350   I bet if they went through the trouble of a new ca...   Jan 15 2024, 11:06 AM
- Lo-Fi Version Time is now: 17th January 2025 - 03:08 PM
