Shifter rod help, '70 914 with sideshift conversion |
VaccaRabite |
Jan 9 2024, 04:24 PM
En Garde! Group: Admin Posts: 13,544 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I'm taking the day off Thursday to help my friend Jon with his 914 over on the MD Eastern Shore.
His car is a 1970 with a tail shift conversion. The engine is in the car. The entire shift rod is out of the car. Both the engine side bar and the bar that goes into the tunnel. In December I was there fixing his 914 ignition and fuel pump wiring before a party broke out. After the party had started I went to go look at the tunnel side shift bar, but I could not figure out how to get it in without dropping the engine. However, I was (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/smoke.gif) having a good time at the party and gave up when I could not immediately figure it out. People to visit, beer to drink. Prior to me getting there Thursday, I figured I'd arm myself with knowledge. 1) is is possible to get the tunnel bar into the tunnel without dropping the motor? 2) if so, how? The 914 is on a full size lift. It seems like this should be easy. Maybe it will be easy when I look at the problem with far more sober eyes. I'm really hoping we don't need to drop the engine to do this. Thanks! Zach |
VaccaRabite |
Jan 9 2024, 08:06 PM
He’s got the sideshift bar.
The issue I ran into last time is the the opening on the bar is offset from the opening on the firewall. I could not find an angle that would let me get the straight bar into the tunnel. Zach |
Spoke |
Jan 9 2024, 10:29 PM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
So the hole for the shift linkage in the engine support bar doesn't line up with the hole in the firewall? I converted my '71 to sideshift using an engine support bar with the hole in it that I got from Bruce Stone and it lined up ok. The engine/trans was out when I converted so your installation isn't quite as easy as mine.
Lo-Fi Version | Time is now: 21st September 2024 - 06:52 PM |
