Engine number missing on my 75 914 2.0 |
Junioren |
Jan 9 2024, 05:52 AM
Newbie Group: Members Posts: 8 Joined: 9-January 24 From: Luxembourg Member No.: 27,840 Region Association: None |
Good morning to all of you readers.
I recently imported a 75 2.0 914. VIN and chassis numbers have been located and seem in order, however I am unable to find the engine number in its usual spot. What could be explanations for having an engine without an engine number? When engines were replaced by VW/Porsche, would these new engines possibly have no number on them? Thanks, Raf (from Luxembourg/Europe) |
dr914@autoatlanta.com |
Jan 9 2024, 09:58 AM
914 Guru Group: Members Posts: 8,124 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
did you look down in the canyon between the oil filler and the front impeller housing?
Good morning to all of you readers. I recently imported a 75 2.0 914. VIN and chassis numbers have been located and seem in order, however I am unable to find the engine number in its usual spot. What could be explanations for having an engine without an engine number? When engines were replaced by VW/Porsche, would these new engines possibly have no number on them? Thanks, Raf (from Luxembourg/Europe) |
Junioren |
Jan 9 2024, 03:37 PM
That is indeed where I checked and was expecting it, but no.
did you look down in the canyon between the oil filler and the front impeller housing? Good morning to all of you readers. I recently imported a 75 2.0 914. VIN and chassis numbers have been located and seem in order, however I am unable to find the engine number in its usual spot. What could be explanations for having an engine without an engine number? When engines were replaced by VW/Porsche, would these new engines possibly have no number on them? Thanks, Raf (from Luxembourg/Europe) Attached image(s) |
Jan 10 2024, 09:06 AM
75 76 air pump 2.0 engine for the 49 states but should not have a vacuum advance hooke up and looks like the oil filler is the earlier one by the size of the hose
That is indeed where I checked and was expecting it, but no. did you look down in the canyon between the oil filler and the front impeller housing? Good morning to all of you readers. I recently imported a 75 2.0 914. VIN and chassis numbers have been located and seem in order, however I am unable to find the engine number in its usual spot. What could be explanations for having an engine without an engine number? When engines were replaced by VW/Porsche, would these new engines possibly have no number on them? Thanks, Raf (from Luxembourg/Europe) |
Lo-Fi Version | Time is now: 17th January 2025 - 03:04 PM |
