MPS rebuild, mission accomplished |
emerygt350 |
Oct 27 2021, 12:07 PM
Advanced Member Group: Members Posts: 2,211 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I just used Chris Foley's excellent rebuild kit on my leaky MPS. After removing the spider webs and varnish it all went together nicely. Chris gave me some great tips on getting an initial set. I think it is there but I don't have any experience with how a well tuned djet 2.0 914 should run. I suspect there is probably 150k or so on this engine although it could be lower, I doubt higher unless it was cared for very very well. Impossible to know with the dead odometer. Compression is great on all cylinders with no variability.
I took a little video of a drive, start up, corners, and two pulls to 60 (of various quality). After the first 40 seconds I opened my sliding rear window so you can hear the engine sounds better. https://youtu.be/Fi4vFCWhlCw |
emerygt350 |
Jan 10 2024, 07:27 PM
I don't know how I feel about that.... The outer stop is important about not nearly as important as the inner two. If someone told me they had messed with only the stop it would take me no time at all to set it back to where it should be. It's the relationship between the inner and outer and then the trickle down effects on the stop that are a beast. Particularly when you have changed the engine from stock.
That said, the device looks great, so does the software. |
Lo-Fi Version | Time is now: 29th June 2024 - 01:58 AM |
