> Engine number missing on my 75 914 2.0
Junioren
post Jan 9 2024, 05:52 AM
Good morning to all of you readers.
I recently imported a 75 2.0 914. VIN and chassis numbers have been located and seem in order, however I am unable to find the engine number in its usual spot.
What could be explanations for having an engine without an engine number? When engines were replaced by VW/Porsche, would these new engines possibly have no number on them?
Thanks,
Raf (from Luxembourg/Europe)
emerygt350
post Jan 13 2024, 10:35 AM
And unless it is a bus 2.0 the intakes on the Porsche 2.0 has 3 bolts. 1.7 has 4. Your spark plugs are in the 2.0 position though, so you certainly don't have 1.7 heads. Not sure if the exhaust on the bus went out the sides or down like the 914.
Junioren   Engine number missing on my 75 914 2.0   Jan 9 2024, 05:52 AM
bdstone914   Good morning to all of you readers. I recently i...   Jan 9 2024, 06:22 AM
Shivers   I had to buy a new case after a disaster. It also ...   Jan 9 2024, 07:37 AM
Junioren   Thanks for the info, much appreciated. So in such ...   Jan 9 2024, 07:59 AM
jhynesrockmtn   Thanks for the info, much appreciated. So in such...   Jan 9 2024, 08:47 AM
Superhawk996   Did you check up at front of engine by the oil fil...   Jan 9 2024, 08:57 AM
davep   There are three locations for the engine serial #....   Jan 9 2024, 09:27 AM
dr914@autoatlanta.com   did you look down in the canyon between the oil fi...   Jan 9 2024, 09:58 AM
Junioren   That is indeed where I checked and was expecting i...   Jan 9 2024, 03:37 PM
dr914@autoatlanta.com   75 76 air pump 2.0 engine for the 49 states but sh...   Jan 10 2024, 09:06 AM
Junioren   A sticker on the engine provides the engine family...   Jan 9 2024, 03:32 PM
wonkipop   A sticker on the engine provides the engine famil...   Jan 9 2024, 08:10 PM
Junioren   Hello guys, I just dump the information I have bu...   Jan 9 2024, 04:04 PM
wonkipop   Hello guys, I just dump the information I have b...   Jan 9 2024, 07:29 PM
fiacra   I thought all EA code engines were 1.7? Can you p...   Jan 9 2024, 06:48 PM
emerygt350   Show us the heads! A 1.7 block is fine if the...   Jan 9 2024, 08:05 PM
JeffBowlsby   Missing a couple important details to know what yo...   Jan 9 2024, 08:08 PM
Junioren   Missing a couple important details to know what y...   Jan 10 2024, 09:03 AM
davep   EA013495 should be an October 1971 engine, but tha...   Jan 9 2024, 09:26 PM
wonkipop   EA013495 should be an October 1971 engine, but th...   Jan 10 2024, 01:48 AM
nditiz1   One thought, it could be a 912E case. They never ...   Jan 10 2024, 07:55 AM
JeffBowlsby   Considering all the above, looks like you started ...   Jan 10 2024, 10:27 AM
Junioren   Considering all the above, looks like you started...   Jan 11 2024, 02:16 PM
JeffBowlsby   Those are capped off air injectors, supplied by yo...   Jan 11 2024, 03:21 PM
rjames   What's with the plugged adapter? Looks like it...   Jan 11 2024, 03:38 PM
wonkipop   What's with the plugged adapter? Looks like i...   Jan 11 2024, 06:16 PM
wonkipop   What's with the plugged adapter? Looks like i...   Jan 11 2024, 07:02 PM
emerygt350   We need to see the ports on the plenum. Looks lik...   Jan 11 2024, 04:04 PM
Junioren   Thanks for all your help on previous questions. ...   Jan 12 2024, 03:20 PM
Shivers   Thanks for all your help on previous questions. ...   Jan 13 2024, 09:27 AM
emerygt350   And unless it is a bus 2.0 the intakes on the Pors...   Jan 13 2024, 10:35 AM
Dave_Darling   All of the Type IV motors have bottom-side exhaust...   Jan 15 2024, 02:28 AM
emerygt350   I bet if they went through the trouble of a new ca...   Jan 15 2024, 11:06 AM
27 User(s) are reading this topic (27 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 17th January 2025 - 03:27 PM
