930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,189 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
![]() Given this former Cali car is coming up on 50 years and probably not always taken good care of, I am lucky to have this level or rusting. I went after it with Ospho, wire brush and clean rinse. ![]() Will be applying POR 15 to this area. Question: my gut tells me the well adhered tar is sound and is not hiding any rusting. |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,924 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Por 15 is trash.
You’re on the right track but once it’s all clean then epoxy primer then body color. Por 15 is well marketed junk just like k&n air filters which is another rabbit hole. |
worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,179 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
Por 15 is trash. You’re on the right track but once it’s all clean then epoxy primer then body color. Por 15 is well marketed junk just like k&n air filters which is another rabbit hole. (IMG:style_emoticons/default/agree.gif) I love epoxy paint. Dry ice will actually work in getting the tar off. Convert the rust or better yet sand it off. Then epoxy. It is expensive but I like the dplf epoxy from PPG. |
930cabman |
Por 15 is trash. You’re on the right track but once it’s all clean then epoxy primer then body color. Por 15 is well marketed junk just like k&n air filters which is another rabbit hole. (IMG:style_emoticons/default/agree.gif) I love epoxy paint. Dry ice will actually work in getting the tar off. Convert the rust or better yet sand it off. Then epoxy. It is expensive but I like the dplf epoxy from PPG. My gut tells me sandblast is best, but too messy for this application. When blasted a decent profile can be obtained to grip the first layer of primer. Ospho is probably the next best |
Lo-Fi Version | Time is now: 19th June 2024 - 01:44 PM |
