zprovo |
Newbie ![]() Group: Members Posts: 19 Joined: 16-September 20 From: Nashville TN Member No.: 24,697 Region Association: South East States ![]() |
I have purchased a 911, so it's time to let the 914 go (or risk divorce).
It was running and driving until February of this year when the fuel pump stopped responding. At that point I parked it and started a renovation on our house and I haven't been back to it. It has a 2056 motor with a Web Cam 73 grind camshaft. 5 speed side shift (converted), Stock D-Jet fuel injection, front mounted oil cooler, a new clutch, Kerry Hunter headers and supertrapp exhaust. I have no documentation to prove the contents of the motor, this work was done two owners prior to me. Though I did speak with the guy (he's in Birmingham) and I have no reason not to believe him. He had nothing to gain by making up a story. Real Minilite wheels and some out of date 5 point harnesses. This car is super fun, though a little loud. In addition to whatever is going on with the fuel pump, the car will need tires and a windshield. Hell hole seems to be in good shape. There is some rust along the back of the trunk. There is no way this car has 24k miles, so TMU. The car comes with the following extra parts: New Front Brake Discs New Front Brake Pads New Rear Brake Discs New Rear Brake Pads New Bosch voltage regulator 914 Rubber turn signal / side marker wiring harness set JW Engineering 914 fuse box upgrade New Front Wheel Bearings New Motor Mounts New Royal Purple Oil Filter New Purolator Fuel Filter Extra Running 2.0 Motor GC002135 from a previous project, complete with fuel injection system Extra side shift transmission Extra used valve covers Original relay/fuse block from engine compartment. 3 Folgers cans of hardware and misc stuff. I would be happy to email additional photos with rocker covers off as well as underside of car if you message me with your email address. $7,500 OBO in Nashville ![]() ![]() ![]() ![]() |
second wind |
Senior Member ![]() ![]() ![]() Group: Members Posts: 862 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California ![]() ![]() |
While you are still available is the front mounted oil cooler in addition to the stock oil cooler or a replacement for the stock oil cooler.....thank you very much!
gg |
Lo-Fi Version | Time is now: 19th April 2025 - 08:30 AM |
