Weber 40 IDF is dripping |
malcolm2 |
Feb 4 2024, 08:36 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Nice day for a drive yesterday.... Drove some, filled up with gas and drove a bit more.
Woke up this morning to smell gas in the garage and noticed a pool of fuel on the floor. I removed the air filter and see a drip in one barrel. 1 barrel is very wet and even has a pool sitting on one side of the plate. The others are wet, so they could be dripping, but less frequent. You know gas, it will evaporate pretty quick. looks to be coming from the center of #14, Aux Venturi. I removed the Main Jet on that barrel (47 - 50), hoping to get it to stop dripping. I think it stopped. What is causing this? (IMG:style_emoticons/default/WTF.gif) I should add that Dual Carbs are new, set up at AC.net... now out of business. Last summer I fully adjusted, and sync'd them. Had been running really well, parked for about a month. Total of about 800 miles on the whole rebuild. |
Robarabian |
Feb 4 2024, 09:51 AM
914 A Roo Group: Members Posts: 653 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
If the carbs are new, it may just be a stuck float valve. Before you remove the tops, maybe pull the float valves and ensure there isnt something gumming them up. The gaskets for the tops tear easily..before you rip into them. I had brand new carbs do this through all three bores. they were laying on the side at some point on the bench and something was stuck. But a small piece of dirt could keep a ball valve open... Otherwise, I agree, could be a bad float in that bowl.
Lo-Fi Version | Time is now: 12th December 2024 - 02:02 AM |
