> Project 3.6 RS Thread, Getting the bugs out and oil line leak
Steve
post Feb 5 2024, 10:57 AM
After 23 years of service out of my 3.2, I decided to buy a used 1995 3.6 from LA Dismantler with 110k miles on it. I paid $25k for the motor, Plus an additional $3k from PMS for conversion parts. Got this motor home and two of the cylinders had bad leak down from the exhaust valves. Lots of goofy issues with 3.6 motors. They have an electric smog pump which clogs the SAI passages in the exhaust valves. Sometimes you can turn the engine over with compressed air through the spark plug openings and use a rubber mallet on the exhaust valves to clear it out. This did not work for me, so I sent my motor out to get a top end overhaul, bigger valves and RS Cams.
This will not be an RS spec motor. RS Spec is 3.8 liters, bigger valves, different injection, etc. My motor is just a 1995 993 motor with one size bigger valves, RS cams and steve wong chip. I asked PMS about the 3.8 slip ins and they said their is very little noticeable difference between the two and not worth it unless your changing the P&C's anyway.
LA Dismantler lessons learned:
-Get a warranty in writing
-Do a leak down at their location before buying the motor.
I did neither and they came up with a ton of excuses not to help me.
This is also true for any wrecking yard. My Euro 3.2 also came from a wrecking yard with no warranty, but that motor was flawless.
This will probably be a very slow progress thread. I still work full time and have a family. I bought this motor two years ago and finally pulled the 3.2 a couple of weeks ago. I sold the 3.2 to the guy that did the top end overhaul on my 3.6. On the 3.2, two of the cylinders had poor leak down, due to weak rings. The motor ran great before I pulled it and all the spark plugs looked the same. So I was very surprised about the leak down results. Besides spending $4500 to PMS three years ago to reseal this engine, it has never been apart. The PMS reseal was due to the normal oil leaks around the cam chain housings and other areas. Who knows how many miles were on it. The guy who bought it said the rings are weak and to spray WD40 in the cylinders. Sure enough it brought the leak down, from 30% down to 3% on one cylinder and from 10% down to 5% on the other. He plans on doing a top end overhaul on it and flipping it or putting it in one of his 914's.
I will add pictures and more info as time goes on.
Old Euro 3.2 motor
Used 3.6 motor
Root_Werks
post Feb 6 2024, 11:19 AM
Village Idiot
Steve,
If you were looking for an option to run hydraulic tappets, my 2.7 uses 993 cam caps and 964 cams with hydro tappets. Would think something similar could be done on a 3.2?
-Dan
Steve
post Feb 6 2024, 01:47 PM
QUOTE(Root_Werks @ Feb 6 2024, 09:19 AM) *
Steve,
-Dan
No reason why it wouldn't work on a 3.2. It's just a cost issue. A 3.6 has a mass air flow meter (firewire) (versus barn door AFM on a 3.2), twin plug and bigger displacement. All can be done to a 3.2 for a price. I'm also a big fan on stock versus mods. I went from 2.7 to 3.2 and now to 3.6.
Mark @mepstein
Why RS cams unless you want to keep the hydraulic tappets? So much better cam options with solid tappets. RS was the biggest I could go and keep the hydraulic lifters. I'm getting older and don't want to adjust valves if I don't have to. Even though I probably adjust valves every 5-10 years since I only use my car for Cars & Coffee and events. I thought about 3.8, but I am not a fan of slip ins and I did not want to split the case (bigger bucks). 4.0 is a ridiculous amount of money. I was told it requires GT3 crank and ITB's.
post Feb 6 2024, 02:25 PM
914-6 GT in waiting
QUOTE(Steve @ Feb 6 2024, 02:47 PM) *
Steve,
-Dan
Mark @mepstein
I misspoke. It’s not an rs cam. It’s very similar to a GT2 evo cam.
ClayPerrine
post Feb 7 2024, 06:51 AM
QUOTE(mepstein @ Feb 6 2024, 02:25 PM) *
Steve,
-Dan
Mark @mepstein
When I did mine, I had the cams reground to 993SS spec. The 993SS cams used solid rockers. I also did the big valves to improve air flow.
When I bought the motor, it was 8 grand for what was definitely a core motor. I had to buy all of the intake and electronics separately off ebay.
And a 4.0L engine does not require a GT3 crank and ITBs. With the proper piston and cylinder set from LN Engineering, you can get 4L out of a 964 motor with the stock crank. You can use the stock intake, but you will leave some horsepower on the table vs ITBs.
Bucci
post Feb 7 2024, 10:52 PM
Bucci
QUOTE(ClayPerrine @ Feb 7 2024, 04:51 AM) *
Steve,
-Dan
Mark @mepstein
Clay, I had to do a rebuild on my stock 3.2 probably 15 years ago. I was zipping down the 57 freeway at about 120 mph. I was driving the motor pretty hard as I normally would. I shifted from 4th to 5th gear on the down down grade, and the motor made a very odd clunk sound after my shift..! I turned off the motor and coasted it into the gas station at the Temple Avenue off ramp. I tried turning the motor over after that point, and it would not spin or even start.. I called a flatbed tow truck and took it back to the shop. I then started the motor again, and it made horrific, gnarly, grinding noise..
Turns out, I actually broke my crank, and the motor was still running, almost sawing through the crankshaft bearing right over a journal in the case.
I ended up rebuilding the motor with a brand new crank from Porsche and I installed 993 Evo/ SS cams, super high lift and very lumpy sounding at idle. At RPM it’s gobbling up the air and has a very high RPM pull or power band. At about 5000+ RPM it is actually pulling harder at the top end which is mind blowing. I would definitely use these cams again, super impressive for a stock injection, set up.
Steve   Project 3.6 RS Thread   Feb 5 2024, 10:57 AM
Steve   Got stripped motor back from the top end overhaul....   Feb 5 2024, 10:57 AM
Root_Werks   Be interesting to get your take on a 3.2 vs. 3.6. ...   Feb 5 2024, 11:20 AM
Steve   Be interesting to get your take on a 3.2 vs. 3.6....   Feb 5 2024, 11:55 AM
Cairo94507   Looking forward to seeing this progress as I am st...   Feb 5 2024, 11:56 AM
SirAndy   I paid $25k out of my 401k for this motor. P...   Feb 5 2024, 01:02 PM
Steve   [quote name='Steve' post='3127183' date='Feb 5 20...   Feb 5 2024, 01:14 PM
NARP74   Unfortunately these prices are the new norm. They...   Feb 5 2024, 02:10 PM
mepstein   Unfortunately these prices are the new norm. The...   Feb 5 2024, 02:18 PM
Steve   Unfortunately these prices are the new norm. Th...   Feb 5 2024, 02:31 PM
Root_Werks   Steve, If you were looking for an option to run h...   Feb 6 2024, 11:19 AM
Steve   Steve, If you were looking for an option to run ...   Feb 6 2024, 01:47 PM
mepstein   [quote name='Root_Werks' post='3127351' date='Feb...   Feb 6 2024, 02:25 PM
ClayPerrine   [quote name='Root_Werks' post='3127351' date='Fe...   Feb 7 2024, 06:51 AM
Steve   [quote name='mepstein' post='3127408' date='Feb 6...   Feb 7 2024, 09:31 AM
ClayPerrine   [quote name='mepstein' post='3127408' date='Feb ...   Feb 7 2024, 09:39 AM
Bucci   [quote name='mepstein' post='3127408' date='Feb 6...   Feb 7 2024, 10:52 PM
ClayPerrine   [quote name='mepstein' post='3127408' date='Feb ...   Feb 8 2024, 01:38 PM
mepstein   We go the opposite on our performance 3.6-4.0 buil...   Feb 6 2024, 12:26 PM
Justinp71   After 23 years of service out of my 3.2, I decide...   Feb 6 2024, 11:40 PM
Lucky9146   Glad you are starting Steve, will be watching and ...   Feb 7 2024, 09:57 PM
eric9144   :popcorn:   Feb 8 2024, 01:31 PM
Steve   :popcorn: :headbanger: You totally lucked out ...   Feb 8 2024, 04:14 PM
kid914   :beer2: :shades2:   Feb 8 2024, 04:25 PM
eric9144   You totally lucked out getting one already done f...   Feb 12 2024, 12:58 PM
Steve   I trimmed the MB911 tin to fit my 3.6 and cut piec...   Mar 17 2024, 06:43 PM
Steve   I trimmed the MB911 tin to fit my 3.6 and cut pie...   Mar 28 2024, 09:46 AM
Cairo94507   @Steve - Hi Steve, Very glad to see you moving fo...   Mar 18 2024, 06:27 AM
Steve   @[url=http://www.914world.com/bbs2/index.php?show...   Mar 18 2024, 08:45 AM
Cairo94507   @Steve Hi Steve - I have a set of the 993 tins a...   Mar 18 2024, 09:07 AM
Steve   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Mar 18 2024, 09:30 AM
Cairo94507   @Steve - Good to know- we shall see how it works ...   Mar 18 2024, 09:34 AM
ClayPerrine   I did the same thing when installing my 4.0 motor....   Mar 20 2024, 02:18 PM
Steve   One week at a time. I can’t get to the rear tin...   Mar 26 2024, 10:48 AM
ClayPerrine   The motor mount is a Rich Johnson mount that Otto...   Mar 27 2024, 03:21 PM
Cairo94507   :popcorn: :beer2:   Mar 27 2024, 08:39 AM
Steve   @ClayPerrine the rich johnson mount bolted right ...   Mar 27 2024, 04:00 PM
SirAndy   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Mar 27 2024, 05:06 PM
ClayPerrine   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Mar 28 2024, 02:18 AM
Steve   [quote name='Steve' post='3136291' date='Mar 27 2...   Mar 28 2024, 08:10 AM
r_towle   Amazing creativity and comradery here on the 914wo...   Mar 28 2024, 08:55 PM
Cairo94507   This is the absolute best car site ever. I have h...   Mar 29 2024, 08:33 AM
Steve   This is the absolute best car site ever. I have ...   Mar 29 2024, 08:57 AM
Steve   Slowly but surely. Wired up Alternator and mounte...   Apr 1 2024, 09:32 AM
SirAndy   ... Also connected up the spark plugs and coils wi...   Apr 1 2024, 11:38 AM
Steve   ... Also connected up the spark plugs and coils w...   Apr 1 2024, 01:27 PM
Cairo94507   That looks nice Steve. :beer2:   Apr 1 2024, 11:23 AM
burton73   @Steve I just sent you a PM Best Bob B   Apr 1 2024, 02:15 PM
Cairo94507   @SirAndy - Note to self. :D   Apr 1 2024, 02:21 PM
Steve   Not much progress. Caught Covid, dog ate my homew...   Apr 22 2024, 12:17 PM
mepstein   They always crack. Luckily they are pretty cheap.   Apr 22 2024, 12:33 PM
Steve   Something else I read on Pelican. If the 3.6 came...   Apr 22 2024, 01:02 PM
rick 918-S   Nice detail. Seems like there are several hot rods...   Apr 23 2024, 09:58 AM
Steve   Plumbed the idle control valve into the new PMS 3....   May 4 2024, 05:57 PM
Cairo94507   Looking good Steve; I appreciate the photos to kee...   May 5 2024, 06:55 AM
Steve   @sirandy [b]@[url=http://www.914world.com/bbs2/...   May 5 2024, 07:48 AM
SirAndy   @[url=http://www.914world.com/bbs2/index.php?show...   May 5 2024, 10:28 AM
Cairo94507   :popcorn: :beer2:   May 5 2024, 08:49 AM
SirAndy   You can sort of see where it all ended up here: h...   May 5 2024, 10:35 AM
SirAndy   And this shows you where my air filter ends up: h...   May 5 2024, 10:37 AM
SirAndy   I think that short 90 degree bend piece between th...   May 5 2024, 10:40 AM
Steve   :beer2: Thanks @[url=http://www.914world.com/bbs...   May 5 2024, 11:39 AM
Cairo94507   @SirAndy and [b]@[url=http://www.914world.com/bb...   May 5 2024, 02:21 PM
Steve   @sirandy looks like you added another 45 degree e...   May 5 2024, 03:38 PM
SirAndy   @[url=http://www.914world.com/bbs2/index.php?show...   May 5 2024, 05:11 PM
Steve   [quote name='Steve' post='3143523' date='May 5 20...   May 5 2024, 05:44 PM
ClayPerrine   I did the same thing. I cut the two tubes apart s...   May 5 2024, 07:36 PM
Steve   I did the same thing. I cut the two tubes apart ...   May 5 2024, 10:06 PM
Steve   Idle control valve connected from the bottom of th...   May 6 2024, 08:45 PM
Steve   While I am waiting for my tin to come back from po...   Jun 3 2024, 01:45 PM
East coaster   I remember doing this on my 3.6, it’s really not...   Jun 3 2024, 05:02 PM
Steve   Hard to find time for this project, but getting cl...   Aug 23 2024, 10:41 AM
Steve   Hard to find time for this project, but getting c...   Aug 25 2024, 07:57 AM
Cairo94507   @Steve Very exciting; looking forward to seeing ...   Aug 23 2024, 11:10 AM
Lucky9146   So glad to hear it is moving forward! Rooting...   Aug 23 2024, 09:34 PM
Cairo94507   I agree; but the PMS harness is not inexpensive. ...   Aug 25 2024, 01:10 PM
Steve   It’s always something.. I had to separate the 91...   Aug 29 2024, 08:01 AM
Cairo94507   Damn, I wish I was down in LA to lend a hand. Qui...   Aug 29 2024, 09:53 AM
Steve   Damn, I wish I was down in LA to lend a hand. Qu...   Aug 29 2024, 10:37 AM
Steve   Getting close. Drive train in car. Oil line leak...   Sep 13 2024, 10:59 AM
Cairo94507   :popcorn: :beer2:   Sep 14 2024, 06:58 AM
Steve   Welds too thick on the MSDS 1 3/4” headers. PIA...   Sep 16 2024, 10:25 AM
Steve   Here’s my Home Depot Motorsports solution to tak...   Sep 20 2024, 01:51 PM
Cairo94507   Nice :trophy:   Sep 20 2024, 02:40 PM
Steve   Finally semi got the car together, but it won’t ...   Sep 23 2024, 06:40 AM
ClayPerrine   Finally semi got the car together, but it won’t...   Oct 1 2024, 02:46 PM
Steve   Finally semi got the car together, but it won’...   Oct 1 2024, 03:43 PM
Steve   Muffler hanger fixed and I am now getting full thr...   Oct 1 2024, 02:11 PM
Cairo94507   I would swap it for the hell of it and see if that...   Oct 1 2024, 04:02 PM
Steve   I would swap it for the hell of it and see if tha...   Oct 1 2024, 07:44 PM
Steve   Still won't start, but I am learning a lot abo...   Oct 28 2024, 09:14 AM
Cairo94507   Man, I know what you are going through and I hope ...   Oct 28 2024, 09:38 AM
Jgilliam914   Steve!!! Geez maybe I should be more a...   Nov 1 2024, 09:53 AM
Steve   Finally running!! Love the RS cams at idl...   Nov 11 2024, 04:02 PM
Cairo94507   @Steve - Congratulations man; I bet those RS cams...   Nov 11 2024, 04:33 PM
Steve   @[url=http://www.914world.com/bbs2/index.php?show...   Nov 11 2024, 05:10 PM
Montreal914   Congratulations!! :trophy: :driving:   Nov 11 2024, 05:29 PM
TMM914   Congrats……..914 stuff…the lows are very low....   Nov 12 2024, 07:36 AM
Steve   Congrats……..914 stuff…the lows are very low...   Nov 12 2024, 08:45 AM
76-914   Congrats Steve. That thing should be quick now...   Nov 12 2024, 05:20 PM
54 User(s) are reading this topic (54 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 5th February 2025 - 08:07 AM
