ibmiked |
Newbie ![]() Group: Members Posts: 41 Joined: 15-June 11 From: Brookhaven, Long Island Member No.: 13,198 Region Association: North East States ![]() |
Hello,
After 8 years of ownership I have decided to move my 1972 914 on to the next owner. This is due in part to the fact that I have recently completed a 3 year restoration on my 1974 European MFI Carrera. There are lots of things to discuss so this will likely span multiple posts. I purchased this car from the third owner in 2016. He purchased the car in 2002 with 41,820 original miles. He then proceeded to spend over $66,000 documented dollars on the car. He had the hell hole and right rocker replaced, and the entire car repainted to a very high standard. Even 20+ years later it is in very nice driver condition. He also had the engine rebuilt as follows: "Raby Aircooled Technology Type 4 engine, 2056cc, 160hp.: flowed, large valve heads, stroked crank, h-beam rods, big bore cylinders, high compression coated pistons, all parts precision balanced, long duration high lift cam, ceramic coated canm followers, high output oil pump, remote oil filter, front valance mounted oil cooler with thermostat, 40 IDF Webers with match-ported manifolds, Mallory distributor, CDi box and rev limiter, stainless steel exchangers, ceramic coated headers." As you can see, he was very intent on making this car a performer and I have all the invoices for the work he did during his 14 year ownership. When I purchased the car in 2016, it had 55,500 miles. It now has 63,825 original miles. The list of work that I have done totals another documented $45,000 in the eight years. That work will be detailed in the next post. SOLD. Thanks for looking, someone is going to get a terrific 914. -Mike ![]() ![]() ![]() ![]() ![]() |
ibmiked |
Lo-Fi Version | Time is now: 24th June 2024 - 06:57 AM |
