7.5mm fuel hose ethanol compatible, Cohline hose failed |
Chaznaster |
Feb 26 2024, 06:55 PM
Member Group: Members Posts: 321 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
I put in new fuel hoses from the gas tank to the fuel pump and pump to line in the tunnel about 6 years ago. I have the tank out and noticed that the first 3 inches of the hose coming from the tank is completely rigid and nearly crumbled in my hand. The inside is all crazed and cracked. It was probably ready to let go on its own ... which would have been messy at best.
The odd thing is that the hose is as flexible as new past the trouble spot and for the rest of the run. It was Cohline 7.5mm hose that I bought from Pelican. The fit was pretty much perfect across all the different fittings on the car. First questions: could this be ethanol incompatibility? Why would only the first 3 inches be impacted? I am shopping for some new hose, assuming the Cohline stuff has compatibility issues. Everything I can find that claims EtOH compatibility is in inch measures. 5/8" (8mm) seems just a hair too big and the 1/4" (6mm) is too small. Next question: can someone point me in the direction of a 7.5mm fuel hose that will stand up to today's US gas formulations? I am running carbs so low pressure hose will do. Finally, if I have to go with 5/8, would there be any concern over leaking? It may be fine with a clamp on it ... Note: I am not able to find ethanol free gas where I am in MA. Many thanks! |
76-914 |
Feb 28 2024, 11:38 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,608 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I've been running Gates Barricade for several years and yes you need to go back and re-tighten the hose clamps every 2-4 years. Good stuff/won't kink. Goodyear makes/made a good product also but it is very susceptible to kinking when bent. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 16th September 2024 - 01:49 PM |
