7.5mm fuel hose ethanol compatible, Cohline hose failed |
Chaznaster |
Feb 26 2024, 06:55 PM
Member Group: Members Posts: 321 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
I put in new fuel hoses from the gas tank to the fuel pump and pump to line in the tunnel about 6 years ago. I have the tank out and noticed that the first 3 inches of the hose coming from the tank is completely rigid and nearly crumbled in my hand. The inside is all crazed and cracked. It was probably ready to let go on its own ... which would have been messy at best.
The odd thing is that the hose is as flexible as new past the trouble spot and for the rest of the run. It was Cohline 7.5mm hose that I bought from Pelican. The fit was pretty much perfect across all the different fittings on the car. First questions: could this be ethanol incompatibility? Why would only the first 3 inches be impacted? I am shopping for some new hose, assuming the Cohline stuff has compatibility issues. Everything I can find that claims EtOH compatibility is in inch measures. 5/8" (8mm) seems just a hair too big and the 1/4" (6mm) is too small. Next question: can someone point me in the direction of a 7.5mm fuel hose that will stand up to today's US gas formulations? I am running carbs so low pressure hose will do. Finally, if I have to go with 5/8, would there be any concern over leaking? It may be fine with a clamp on it ... Note: I am not able to find ethanol free gas where I am in MA. Many thanks! |
r_towle |
Feb 26 2024, 08:39 PM
Custom Member Group: Members Posts: 24,620 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Agree!
Also Northern Foreign Autoparts in Nashua stocks the right hose. Can’t recall the places near you…it’s been 25 or more years since I lived down there….. Maybe Maynard, or Acton has a decent autoparts place still?? Bell metric is for sure a place to know, and shop. What I learned. With carbs, it’s better (easier) to have a fuel shutoff before the carbs. Park car, turn off shutoff, let idle till it dies. This removes the fuel from the carbs and you won’t need to clean them as often. Turn on, wait till fuel pump tone changes, the carb bowls are full. Then crank. |
MikeM |
Feb 29 2024, 12:32 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Agree! Also Northern Foreign Autoparts in Nashua stocks the right hose. Can’t recall the places near you…it’s been 25 or more years since I lived down there….. Maybe Maynard, or Acton has a decent autoparts place still?? Bell metric is for sure a place to know, and shop. What I learned. With carbs, it’s better (easier) to have a fuel shutoff before the carbs. Park car, turn off shutoff, let idle till it dies. This removes the fuel from the carbs and you won’t need to clean them as often. Turn on, wait till fuel pump tone changes, the carb bowls are full. Then crank. Hello...I like this idea of a fuel shutoff valve. This might stop my percolating problem on hot days!! I wonder how long it would take to drain the carbs at idle? Thanks. |
Lo-Fi Version | Time is now: 16th September 2024 - 02:09 PM |
