914ltd |
Member ![]() ![]() Group: Members Posts: 243 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None ![]() ![]() |
I first used these while working at a Porsche dealership in the early 70's. I believe we purchased them from a VW dealer.
This little device slows down the heat getting to the head temp sensor and after initial warm up, it has no effect on running. $30. with 2 copper seal rings. Post included Does not include the head temp sensor. Attached thumbnail(s) ![]() ![]() |
914ltd |
More available. $30. with post |
StarBear |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,118 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
914ltd |
More available. $30. with post It seems (?) that this might make the CHT sensor easier/faster to replace (if the extension stays in place)? What’s the likelihood that removing the CHT unscrews the extension, too? Interesting potential. Hopefully you won't need to remove the CHT often. It's probably about 50/50 that it would stay in the head unless you use Locktite. A small dab of anti seize on the CHT itself would also help. Keep in mind you are installing a steel threaded part into the much softer aluminum cylinder head. The threads can strip out easily. Brad |
Lo-Fi Version | Time is now: 29th April 2025 - 07:36 AM |
