> Starter, No click at starter with ignition or remote start
rgare
post Mar 22 2024, 01:20 PM
No click
- Resistance between negative battery to starter case: 0.3
- Voltage at the the battery: 12.73
- Voltage at the starter: 12.73
- Voltage at the ignition spade while cranking: 12.53
If I connect a remote between the battery lead on the starter and the ignition spade on the starter and a multimeter to the battery lead, voltage drops from 12.7 to 2, when I press the remote. The starter doesn't click or engage. (I don't know what to think of that)
I just got the starter back from a local rebuilder with a good reputation. Before I take it back and have him check it, does anyone have any ideas?
r_towle
post Mar 22 2024, 05:04 PM
Custom Member
I did at one point buy a 3 foot black ground lead that bolted to the upper start bolt, and the negative battery terminal…solved it.
Then I finally found new ground strap for trans to body…fixed the issue.
- Lo-Fi Version Time is now: 6th January 2025 - 09:10 PM
